Most of the time I used DI water from a lab.
We had a filtration system at the radiator shop. Once filtered our 400 ppm water was 3-4 ppm.Most of the time I used DI water from a lab.
You are of coruse correct and itis nonetheless creepy.I have never seen an automotive repair facility with an inventory of distilled or deionized water jugs sitting on the shelf.
No offense to the person who linked it, but this is an odd article, and the "reasoning" is spurious.I've always used distilled but have also read from authoritative sources that deionized is acceptable too. I've never questioned it until seeing this thread. Rislone seems to suggest softened water is preferable to distilled for similar reasons you stated:
https://rislone.com/blog/cooling/why-you-should-never-use-distilled-water-in-your-cooling-system/
Its late and I dont want to type too much but I recommend to follow the rest of this thread over that link.
I don't really follow, "over that link"?No offense to the person who linked it... but I recommend to follow the rest of this thread over that link.
This is somewhat of a typical complaint that in actual practice makes zero difference whatsoever.A little intro first. If you were to search my user name you'll find it scattered all over the net , mostly in technical forums. I've a fair amount of technical experience in a lot of different areas. I've very occasionally mined this forum for intel for years, but never really had reason to participate until now. I've a question that this forum seems best poised to address.
I first ran a search and didn't really find what I was looking for. The universal advice with diluting coolant is to use distilled water. No need to go into why to not use tap water. I have first hand experience with that from before I knew better. If I've missed a thread that really addresses my question then please point me to it.
However, distilled water is fairly active chemically. Those ions that were stripped out of it in the distillation process have left behind "holes" that want to be filled. Ooo lookie, some heated aluminum! That sort of thing......
In steam turbine generators the chemistry of the water used is very carefully monitored and controlled. They start with RO water, then distill it. And then add back in very specific chemicals in very specific amounts to arrive at precisely the right water chemistry. Whatever that is. Learning this while I worked at one of those steam turbine generating plants started me in questioning the near universal distilled water doctrine.
So, is distilled really the best answer? If not, assuming it exists what is the better answer?
No, Deionized should be 0ppm.I'm curious what the "ideal" water would be for coolant mixing. PH, TDS, GH?
Is RO water with a TDS of 50 as good a de-ionized? Does it really matter?
It’s not the “activeness” of the water. Both are polar liquids and are miscible.So the activeness of pure water is where those hydrogen bridges are forming instead of the water molecules pulling out metallic ions to bond with? Seems a reasonable assumption.
Also seems reasonable to assume that if a highly mineralized tap water were used instead that there would be fewer of these bridges, which would have a degrading effect on the overall behavior of the solution.
It’s because you don’t know what some of the words mean.I think that most of this thread would disagree with "water being very stable" If you strip out the mineral ions it actively tries to replace them with whatever it is in contact with, usually that being metallic ions. Once it has those it is still a very effective solvent.
