“Dished Tip” Trim Pad Tools
At those prices, I'd seek different tools for the job of removing 'push clips'.
I worked on a neighbor's Honda Accord and he'd grind away at least 4 of them every time I saw the car.
Having replacement clips on hand is one thing to consider.
Work for yourself or are you in a dealership?
I primarily work on Hondas and find these pliers to be of immense help in removing the plastic push-pin type clips used to fasten underhood and undercar trim panels.
DURATEC 2-piece Trim Pliers
While these are inexpensive, I have found these trim tools work well to pry off Honda interior panels without scratching:
Auto Trim Pry Tools
YES!! I've always wanted a trim tool that can also spray plastic!
In all seriousness, I don't have a set exactly like that, so I ordered.
I’ve never found those tools to work that great/easily/not create collateral scratching.
I’ve found the older type to work best. Thin, sharp-edged ones.
  • Like
Reactions: D60
I would head to my vise with a torch and play blacksmith to bend up one of my amazon specials.
