Discount oil in Oz.
At Autobarn in Australia, to 2nd June 2019
Nulon 10W40 Semi-Synthetic
API SN, ACEA A3/B4, MB 229.3, VW 502/505
KV100 = 15.08 cSt, TBN = 11, Sulphated Ash (SA) = 1.1%
55% off, $18 for 5L
Mobil Super 2000 5W30 Semi-Synthetic
API SN, ILSAC GF-5
KV100 = 10.6 cSt, SA = 0.9%, HTHS = 3.1 cP
50% Off, $24 for 5L
At REPCO in Australia, 23rd May to 2nd June
Penrite Vantage 15W40 Semi-Synthetic
API SN, ACEA A3/B4, VW 502/505
KV100 = 14.8 cSt, TBN = 10.1 , Zinc = 1090 ppm, SA = 1.29 %
50% Off, $24 for 6L
Penrite HPR-5 (5W40) Full Synthetic
API SN/CF, ACEA A3/B4, BMW LL-01, MB 229.5, Porsche A40, VW 502/505
KV100 = 14.4 cSt, TBN = 10.4 , Zinc = 1240 ppm, SA = 1.28 %
$39 for 5L (save $29)
Penrite Enviro+ Diesel C3 5W30 Full Synthetic
API SN, ACEA C3, BMW LL-04, MB 229.51, MB 229.52
KV100 = 12.1 cSt, TBN = 7.8 , Zinc = 810 ppm, SA = 0.78 %
$49 for 5L (save $20)
Penrite Enviro+ 5W20 Full Synthetic
API SN, ACEA C5, ILSAC GF-5, STJLR.51.5122 (Jaguar)
KV100 = 8.4 cSt, Ca = 0.183%, Zn = 890 ppm, SA = 0.77%
$50 for 5L (save $19)
At Supercheap Auto (SCA) in Oz, 22 May to 2 June
Penrite 5W30 Full Synthetic
API SL (high ZDDP), ACEA A5/B5, Ford WSS-M2C913-D
KV100 = 9.6 cSt, TBN = 10.1 , Zinc = 1050 ppm, SA = 1.09 %
$39 for 6L (save $26)
Penrite 10W40 Full Synthetic
API SN/CF, ACEA A3/B4, BMW LL-01, MB 229.5, JASO MA
KV100 = 14.9 cSt, TBN = 10.2 , Zinc = 1080 ppm, SA = 1.21 %
$38.40 for 6L (save $25.60)
Also at Repco (as above)
Penrite Enviro+ 5W-40 Full Synthetic
It's API SN/CF, ACEA C3, Dexos2, MB 229.51, BMW LL-04, Porsche A40
KV100 = 13.4 cSt, TBN = 8.0, Zinc = 890 ppm, SA = 0.8%
$50 for 5L (save $18)
For those Dexos2 users in Australia running GM-Holden vehicles.
Somehow I have access to Penrite Enviro, i am wondering if anyone tried the 5w20 or 0w20 before and whether their durability comparable with Castrol Edge or Mobil 1?
Hey Mate,
I've used a lot of Penrite oil, but always the high-SAPS thicker stuff, never the low/mid-SAPS thinner stuff. But Penrite make a good oil and I'm sure it's a fine product.
The "best" Penrite oil is their 10-Tenths series that is 100% PAO and Ester (Group IV and V). Most of their other full synthetics are Group III, but the Enviro+ series is made with varying amounts of Group III and Group IV (PAO), according this document
Traditionally Penrite oils have been thick with a heavy add pack, so high-SAPS (SA%) with high TBN and high ZDDP (zinc). It's what the Aussie driver wanted back in the day, when driving old school V8's through the outback (Think Mad Max the original).
Now modern cars require thin oil for fuel economy, with low/mid-SAPS to protect the DPF or exhaust catalyst. So Penrite made the Enviro+ series to meet this modern demand.
I'm sure the Enviro+ oils are good, but so too would be equivalent products like Mobil 1, Castrol Edge, Valvoline SynPower and Shell Helix Ultra. I would just buy a name brand synthetic that meets your spec and offers the best price.
For me Shell Helix Ultra and the full synthetic Castrol Magnatec are often the best priced oils that carry the specs I need. If you get Penrite at a good price, then buy it, otherwise M1 or Edge would do me fine. I should add that M1 is known to use decent amounts of PAO in many of their products, and SHU uses the excellent GTL base. All good choices.
At Repco, 3-5 June
It's 25% off all Castrol engine oil.
BTW last weekend they also had 40% off wiper blades, so I changed my old rubber for new. Windscreen wipers seem to cost a lot more now days with their new designs. Glad to get 40% off, and they needed changing.
At Repco 6-16 June
Castrol Magnatec 10W-40 semi-synthetic
It's $26 for 5L (save $23)
At SCA 5-16 June
Penrite HPR5 (5W-40) Full Synthetic
API SN/CF, ACEA A3/B4, MB 229.5, BMW LL-01, Porsche A40, VEW 502/505
40% Off, $37.20 for 5L
API SN/CF, ACEA C3, GM Dexos2, MB 229.51, BMW LL-04, Porsche A40, VEW 502/505
KV100 = 13.4 cSt, TBN = 8.0 , Zinc = 890 ppm, Sulphated Ash = 0.8 %
At SCA 5-16 June 2019
25% Off selected Valvoline SynPower Full Synthetic oils (5L jugs)
0W20
API SN Plus, GM Dexos1-Gen2, ILSAC GF-5, Ford 947-B1, MS-6395
5W-40
API SN/CF, ACEA A3/B4, BMW LL-01, RN 710/700, VW 502/505
5w30 ENV C1
ACEA C1, Ford 934-B, JLR 03.5005
5w30 FE
API SL/CF (High ZDDP), ACEA A5/B5, Ford 913-D, JLR 03.5003
0W-30 DT C2
ACEA C2
5w30 MST
5W-40 MST
API SN/CF, ACEA C3, GM Dexos2, MB 229.51, BMW LL-04, RN 710/700, Porsche A40
At Autobarn in Australia, 8-16 June
Castrol GTX 15W-50 High Mileage, mineral oil
API SN (only spec)
75% Off, $10 for 5L
Nulon 5W30 Semi-Synthetic
API SN and ILSAC GF-5
KV100 = 11.47 cSt, TBN = 8.1 , SA = 0.8 %, FP = 220C, CCS (-30C) = 6040
35% Off, $27 for 5L
Nulon European 5W30 Full Synthetic
API SN, ACEA C3, MB 229.51, VW 504/507
KV100 = 12.04 cSt, TBN = 5.4 , SA = 0.5 %, FP = 227C , CCS (-30C) = 6220 cP
It's $60 for 5L (save $20)
Nulon Long Life 5W30 Full Synthetic
API SN, ILSAC GF-5, Dexos1-Gen2
KV100 = 10.66 cSt, TBN = 8.5 , SA = 0.9 %, FP = 236C, CCS (-30C) = 6020 cP
It's $45 for 5L (save$20)
Penrite HPR5 (5W-40) Full Synthetic in new 7L container
API SN/CF, ACEA A3/B4, MB 229.5, BMW LL-01, Porsche A40, VW 502/505
KV100 = 14.4 cSt, TBN = 10.4 , Zinc = 1240 ppm, SA = 1.28 %, CCS (-30) = 6400 cP
40% Off, $54 for 7L (save $36)
Valvoline EngineArmour Semi-Synthetic in 6L container, 25% Off
15W40 - API SN/CF, ACEA A3/B4
10W30 - API SN/CF, ILSAC GF-5
5W30 - API SN, ILSAC GF-5 (note: Valvoline says "This product is NOT recommended for use in diesel engines", which they didn't say for the other two.)
Valvoline Fuel Injector and Carby Cleaner (350mL) for $2 (save$6). I've used this before, and it seemed to help.
Ryco oil filters are 15% off.
At Repco, 6-16 June
Castrol Magnatec 10W40, semi-synthetic
API SN/CF and ACEA A3/B4
KV100 = 14.5 cSt, SA = 1.2%,FP = 203C CCS (- 25C) = 6100 cP
Castrol Magnatec 10W30 Stop-Start, semi-synthetic
API SN and ACEA A3/B4
KV100 = 12.4 cSt, SA = 1.22%, FP = 202.5C, CCS (- 25C) = 6640 cP
It's $37 for 5L (save $13)
The higher CCS for the lower KV100 makes me prefer the 10W30 Magnatec over the 10W40, both are SN & A3/B3/B4 oils.
Castrol FP via D93, Nulon via D92
At Repco, 6-16 June
Castrol Magnatec Diesel 15w40 semi-synthetic
KV100 = 14.9 cSt, SA = 1.2%, FP = 202C
It's $59 for 10L (save $29)
A slightly thicker and more shear resistant version of Magnatec 10W40 ?
SR5, how do you go about finding these deals in advance?
Visiting AU and need to change oil in a car that was nicely lent to me. Driving is interesting down under for a left hand driver, luckily Ausies are very forgiving & polite.
Keep up the good work.
Thanks mate. Enjoy your time in Oz.
These are their regular catalogue sales, I just google them (e.g. Repco Catalogue) and see what I get.
I checked earlier this week and nothing, but today both SuperCheapAuto (SCA) and Repco have sales on. They don't advertise in advance, so you just need to keep looking.
The reason I've decided to keep adding to one thread, rather that start multiple short threads, was so that you can look back at the dates and begin to estimate when the next sale is approaching. Plus it allows you to compare prices and it keeps BITOG a bit tidier.
At SCA 19-30 June
Castrol Magnatec 10W40 semi-synthetic
50% Off, $23.40 for 5L
API SN, ILSAC GF-5, Chrysler MS-6395, Dexos1-Gen2
50% Off, $32 for 5L
At Repco 20-30 June
Castrol GTX UltraClean 15W40 semi-synthetic
API SN/CF and ACEA A3/B3
50% Off, $20 for 5L
Castrol Magnatec SUV C3 5W30 Full Synthetic
It's $49 for a big 7L (yes seven) jug
This is their very new stuff
At Repco in Australia, 20 to 30 June 2019.
Castrol RX Diesel 15W40 mineral (green)
ACEA E7, API CI-4/SL, CAT ECF-2, Cummins CES 20077, CES 20078 DDC Powerguard 93K215, Deutz DQC III-10, Mack EO-M Plus, EO-N, MB-Approval 228.3, MTU Oil Category 2, RVI RLD-2, Volvo VDS 3, Meets requirements of MAN M3275-1
It's $89 for 20L (save $40)
Shell Helix HX8 5W30 Full Synthetic
API SN/CF, ACEA A3/B3/B4, MB 229.3, VW 502/505, RN 700/710
It's $43 for 5L (save $24)
Shell Helix Ultra 0W20 Full Synthetic
API SN, ILSAC GF-5, ACEA A1/B1
It's $69 for 5L (save $27)
Shell Helix Ultra ECT 0W30 Full Synthetic
ACEA C2, ACEA C3, API SN, VW504.00/507.00, MB 229.52, MB 229.51, MB 229.31, Fiat 955535.GS1 & Fiat 955535.DS1 (meets requirements), Porsche C30.
It's $59 for 5L (save $27)
Shell Helix Ultra 5W40 Full Synthetic
API SN/CF; ACEA A3/B3, A3/B4; BMW LL-01; MB approval 229.5, 226.5; VW 502.00/505.00; Porsche A40; Renault RN0700, RN0710; PSA B71 2296, Ferrari. Meets the requirements of Fiat 9.55535-Z2 and Chrysler MS-10725
It's $59 for 5L (save $16)
Hi SR5, hope you don't mind me posting in your thread.
Spotted some reasonable prices on Ryco Syntec Oil Filters - Z418ST, Z386ST, Z495ST are currently the same price as the regular Ryco filters at Sparesbox eBay. With the code PAUTO15 the price comes down to $12.25 each with free delivery. Some other good prices on Syntec filters, but these ones seem to be the only ones reduced to same price as the regular Ryco's.
Chief Cherokee Semi-synthetic Engine Oil 5 Litre $16.49 @ SCA
API SM/CF and ACEA A3/B3/B4
According to one review the additives have changed since they repackaged it.
At Repco, 1st to 7th July
Castrol Edge 5W30 A3/B4 Full Synthetic
It's rated API SL (high ZDDP, but passes SN tests), ACEA A3/B4, MB 229.5, BMW LL-01 and VW 502/505.
So, Noack volatility below 10%, TBN above 10, and Zinc around 1000 ppm.
It's $44 for 5L (save $31)
Castrol GTX 20W50 mineral, API SN/CF
It's $19 for 5L (save $16)
Valvoline SynPower DX1 5W30 Full Synthetic
API SN-Plus, ILSAC GF-5, Dexos1-Gen2, Ford 946-B1
It's $43 for 5L (save $28)
Valvoline SynPower FE 5W30 Full Synthetic
API SL/CF (High ZDDP), ACEA A5/B5, Ford 913-D, JLR 03.5003, Fiat 9.55535.G1
It's $50 for 5L (save $25)
Valvoline SynPower XL-III 5W30 Full Synthetic
ACEA C3, MB 229.51, BMW LL-04, Porsche C30, VW 504.00/507.00 (Oh No !!!, it has no API spec)
KV100 = 11.7 cSt, TBN = 6.7, FP (D92) = 232C, PP = -45C
Valvoline SynPower 5W40 Full Synthetic and Full SAPS
API SN/CF, ACEA A3/B3/B4, MB 229.3, VW 502.00/505.00, RENAULT RN710/700
It's $43 for 5L (save $25)
At SuperCheapAuto, 3-14 July
Noack volatility below 10%, Zinc around 1000 ppm, HTHS = 3.6 cP and TBN is 10.2
50% Off, $36 for 5L
Valvoline Super Diesel 15W40 mineral oil
API CH-4/SJ, ACEA A3/B3, MACK EO-M PLUS, VOLVO VDS, VDS-2, JASO DH-1
50% Off, $23 for 5L
