Originally Posted By: artificialist
Originally Posted By: gregk24
Dont all engines with timing chains have guides and tensioners?
Pushrod motors don't.
Back in the past, they may have been built without tensioners, but sometime later, tensioners were used with some OHV engines. The Chevy Caviler is the first example that comes to my mind.
Also, older OHV engines still had timing guides. There would be a triangular shaped block that matched the space between the upper and lower sprocket.
Most old V engines used none, the cam and crank sprockets were very close to each other, a tensioner would be pointless.
On engines like the 2.0 in the Cavalier with an offset cam gear or with more distance between the sprockets they used a tensioner/slipper.
