Direct Injection specific oils
Originally Posted by RDY4WAR
Originally Posted by dave1251
Sorry. I don't buy into this with only 250 PPM of calcium for detergent with nothing else. It would make a decent racing oil because it's changed after each race and the majority of engines are torn down.
Mobil knew about this 8 years and everyone was wondering why their oil had 1,100 ppm of calcium. Most oils have 700 to 1,350 ppm of Ca. and minus Sodium too remember. That are LSPI speced. Amsoil SS has 1,300 an is 100% LSPI certified. Boron and Magnesium in it's place and who knows behind the VOA scene we can't see.
Plus SN+ oil is no grand spec, compared to Mercedes Benz and VW specs it is SO meagerly.
You missed it. A street driven oil needs more detergent then 250PPM with a TBN of 2.
The Driven XP oils with just 250 ppm Ca are not advertised for street use. They are strictly race oils. Short chained, secondary ZDDP. Loads of tri-nuclear / organomoly blend. No VIIs. A friend of mine runs this oil in his MASS Street Stock car. He only changes the oil once a year at the beginning of the season. After each race weekend, he changes the cheap Fram filter and tops off 0.5 quart to refresh the oil.
http://www.drivenracingoil.com/dro/products/competition-race-engine-oilshtml
Driven XP3 10w-30
KV100..............11.7
KV40................67.87
VI.....................169
TBN.................1.3
HTHS...............3.64
Ca....................256
P.......................963
Zn.....................809
Mo....................1755
They are formulated very differently from their street oils.
http://www.drivenracingoil.com/dro/products/street-performance-engine-oilshtml
http://www.drivenracingoil.com/dro/products/hot-rod-engine-oilshtml
Driven LS30 5w30
KV100..............11.04
KV40................64.1
VI.....................166
TBN.................10.1
HTHS...............3.48
Ca....................2850
Mg....................160
P.......................1190
Zn.....................1300
I don't have specifics on the DI20, DI30, DI40, and DI60 oils but know they are formulated with a Ca/Mg blend like other D1G2 and SN Plus oils.
Well the LS30 has quite a bit of Calcium it would be interesting to see if it prevented LPSI.
Driven XP3 10w-30
Driven LS30 5w30
It's not advertised to deal with LSPI. That's what the DIxx oils are for which I addressed in the last sentence.
I actually should correct myself. Those specs on the LS30 is an old formula. The new formula has slightly less ZDDP and contains around 400 ppm of tri-nuclear moly. Same with the other synthetic street oils.
