Dipstick reading issues.
Montreal,Canada
I always check my oil and its usually fine, however when I checked it this morning it gave a solid reading up to the max mark and then there is a load patches of oil going half way up the dip stick. Much appreciated thanks.
The same thing happens to me if I don't wipe the dipstick off before checking the level.
I always check my oil and its usually fine, however when I checked it this morning it gave a solid reading up to the max mark and then there is a load patches of oil going half way down the full mark. Much appreciated thanks.
Originally Posted By: postjeeprcr
So the patches of oil are after wiping it off and reinserting it and pulling it back out?
Yes
Originally Posted By: Big_Kat
It could be just oil that's on the inside of the dip stick tube.
Oil can't drain from the tube because there's an o-ring on the dipstick. Just ignore random oil patches.
I had trouble with the shape of the tube affecting the dipstick readings on a Honda Civic. It didn't leave patches on the dipstick, but rather a sharply slanted oil line vs. a straight line. I learned to twist the dipstick while removing it.
