Originally Posted By: route66mike
Originally Posted By: BrianC
Quote:
Wrong. Newer vehicles from GM, and other makes, now have oil level sensors. (You're talking about the pressure sensors, a different animal.) BMWs have had an oil level sensor, either just a threshold low sensor or graduated levels, for about 14 years now.
Yes, some vehicles may have a level sensors. But I would venture to say most vehicles on the road today do not and only indicate low or no oil pressure. And as an owner/driver, it would be good to know how their vehicle was equipped. (read manual) Obviously, the OP's apparently did not, or it didn't work.
The vehicles I drive daily (motorcoaches) have both oil and coolant level sensors, that will shut the engine to an idle and then totally down if either low coolant or oil is detected. So I am aware of them.
Either way, nothing beats physically checking the oil a minimum of once a month (each fuel up is better) in your car regardless of what fancy indicators it may have, or what oil is in the sump.
I disagree. With the new-ish oil level sensors increasingly in use, one can wait for the level warning light to come on. It comes on when its just over a quart low, which is still plenty of time for the driver to put a quart in at that time. Keep 1/2 quart in the trunk to be safe in case on a trip. Timesaver, and it also catches leaks before they get too severe. Still, its good to open the hood and take a look around. BMW agrees with me, as there are no dipsticks on BMWs one engines made within the last 8 years (except some V8 ones).
You can't be serious.
BMW is removing any and all dipsticks and whatnot so that the owner must take the vehicle in to them for service. If you believe otherwise I've got a bridge to sell you.
And I find it truly laughable that a person would rather depend on technology that can fail,to tell them their oil is low rather than physically check themselves.
And think about it. If your driving around with the oil a quart low for any extended period of time the oil is accumulating more contaminants and acid per fluid ounce than if it was full,which inevitably kills the oils tbn much faster and means the oil will not last as long as it could potentially had the sump been full.
Firstly I check all my fluids in all my engines weekly.
And even though none of them consume any fluids I check them anyways. Call it my need to be informed.
You know I've read and heard much about owners of BMW's that just fly blindly and end up, due to their own personal negligence,with engines that are sludged up because they never check the condition if the oil and figure that the oem recommended service interval is just sort of a guideline and not really set in stone.
I never truly believed that there were people out there who just drove,never really monitoring the condition of their fluids and just took it into the dealer when there's an issue.
Low oil is an issue regardless of what you might think.
If a 5 quart sump is a quart low that's 20% low,which means the interval requires shortening by 20% at the very least.
I'm in awe here. And now I understand all I've read and heard.
If there's no idiot lights on drive on right?
Hillarious
