You are getting good advice here. My 2 cents:
Just follow the owner's manual's viscosity recommendation. If your car sees 0F, use 5w-30. If it doesn't, then 10w-30/10w-40. 10w-40 especially if you run it hard.
The Subaru crowd's general believe is to use dino until 10k miles. My rationale is that using dino in short intervals is not going to hurt the car, and that was what I did with my WRX. First oil change @ 2600mi with Mobil 10w-30. Then did 3 changes at short intervals with Chevron 10w-40 until I reached 10k miles.
Then I used Mobil 5w-40 from 10-15k (had UOA), then Mobil 0w-40 for 15-20k and 20-25k. At 25k I switched to Mobil EP 10w-40 and I currently have 26k on the car. I burn some oil towards the end of my 5k oil changes with Mobil 5w-40 and 0w-40, maybe 1/2 qt or so. Hopefully the 10w-40 EP will fair better.
If you are "extra paranoid" about warranty, make sure you use the Mobil 5w-30/10w-30 which meets the API SM and GF-4. I am not saying that you will have trouble with warranty running other oils though, which I personally don't. But since you are going Cobb Stage 2 anyway, I assume you won't be concerend about this.
Hopefully you get your Cobb Stage 2 pro-tuned. I currently have Cobb Stage 1 and is thinking about Stage 2 too.
quote:
Originally posted by XenoX:
SilverGGA- The wrx will have Cobb stage 2 285 hp at the flywheel downpipe and ecu map changes, I hear it is a conservative tune.
