I've tried several searches for differential and tranny lube recommendations for 7.3l PSDs and came up with nothing. Suggestions? I would like to go synthetic with the differentials (4X4). I have a ZF 5 speed manual tranny which is spec.'d for synthetic ATF.
Two reasons for these requests:
1. I'm going to be carrying a 9 and a half foot camper here shortly and would like to change to a synthetic differential fluid.
2. I'm currently running AMSOIL ATF in the tranny which has helped some with a second gear downshift problem when cold. This shifting problem started when I had to replace the two piece flywheel/clutch assembly. Unfortunately, I chose to go with an aftermarket, single piece flywheel/clutch. I don't think the new clutch is strong enough to handle well the PSD equipment. There were no tranny problems prior to the switch.
At this time I don't have the money to switch back to a two piece flywheel/clutch assembly, so am trying to maximize my truck's performance with the best lubes I can come up with.
As an aside, the Ford syn. ATF specified for the ZF manual transmission isn't nearly as good a performer as the AMSOIL, given the tranny issue I've got. Are there other synthetic ATFs that might work better? I know AMSOIL has come out with a couple of new tranny fluids in the last year or so. How about Royal Purple's Synchromax (I think that's the name of it). Any other ideas?
In short, what differential and tranny fluids would you recommend for my '95 PSD 4X4 with ZF 5 speed mannual tranny (specified for synthetic ATF)?
Thanks.
Thanks.
