Hi,
I've asked this question in other forums but have never gotten any good answers.
2 Questions:
1. What is the difference between a truck diesel engine oil (heavy duty probably) and a car diesel engine oil (normal duty probably)?
2. Should I avoid using heavy duty engine oils in normal passenger diesel cars (of course observing viscosity requirements)? And why?
From reading about standards I've concluded the following:
MB228.XX series is for heavy duty engines
MB229.XX series is for light duty engines (passenger cars)
ACEA EX series is for heavy duty engines
ACEA AX series is for light duty engines (passenger cars)
API CX series does not not distingguish between heavy duty and light duty engine oils
Please correct me if I'm wrong.
From reading the ACEA standards the only main difference between EX and AX series is the ash content - it has a higher threshold in EX series. Also something about foaming capabilities as I remember.
ACEA Standard
Furthermore I see that AX series are tested for different properties than EX series.
Maybe somebody can enlighten me
Lucas
2 Questions:
ACEA Standard
Lucas
