I have an old Oliver 1655 Diesel tractor that, particularly at startup, blows a fair amount of blue smoke at idle to 1200 rpms or so. At higher throttle speeds the exhaust is clear as a bell. Not really sure what to make of it--I have auto-rx'd it, and am past the rinse stage now. No help.
It does use a bit of oil, but isn't real bad. It was overheated by my brother once a few years back, and there is very slight oil seepage around the HG on the rearmost cylinder where the exhaust manifold attaches. Tractor doesn't run hot, OP is 30 at hot idle, and maxed out at 50psi at 1500rpms and above. Oil does not show obvious signs of water/coolant contamination, nor does antifreeze show signs of oil. I have noticed that the front of the radiator contantly gets oily and greasy and has to be cleaned periodically to keep tractor from running warm. I don't know if that's a warning sign or if it is just sucking blowby in since it is used stationarily on pto duty and as a loader tractor 99% of the time. Tractor doesn't have a ton of blowby, but some is evident. It runs very well.
Any suggestions on what is going on?
