Jet fuels have static dissipation and anti-ice additives which cause deposits in diesel fuel systems. Don’t use them in a diesel unless it’s life or death.
Jet-A is really only a problem if "Prist" additive is requested, it will not be added unless requested, due to the above mentioned downsides that can also affect aircraft. Otherwise Jet-A is a very pure and pretty much an unadulterated Kerosene product. The static dissipator "statis 450" is the very same one used in diesel fuels, gasoline, kerosene and just about every other fuel everywhere.
Just an FYI on Prist. It is an expensive anti icing additive (Diethylene Glycol Monomethyl Ether) that is used typically on turboprops and smaller Jet-A burning aircraft, to prevent fuel starvation due to ice. It is not commonly used on larger jets that operate in much colder environments, as larger jets have systems that heat the fuel, along with some aerodynamic heating of the wings at higher Mach numbers (above about M0.8) we can see this on the fuel tank temp indications, which can be well above the outside temps of -70ºF. It is not unusual to see 55ºC engine fuel temps on the Gulfstream G600 with outside temps well below 0º.
For about 2 decades now, we've operated a wide range of diesel engines on Jet-A. Knowing the lubricity was lower than #2 Diesel, we tested various additives and samples. Additives such as Marvel Mystery Oil and Automatic Transmission Fluid had already been tested and shown to be poor choices. So we concentrated on what worked. Stanadyne Lubricity Additive and TCW3 Two stroke oils.
HFRR (high frequency reciprocating rig, the standard for injection system lubricity) results, smaller wear scar is better (by memory):
Jet-A without Prist or other additives, as high as 650µm, well above the 450 limit here in the USA and the 520µm Euro limit for #2 Diesel
Pump #2 Diesel About 300-350µm
Jet-A with 100 to 1 TCW3 and Stanadyne Lubricity additive 255µm
In the end, it was the TCW3, even at 200 to 1 provided the lubrication necessary to bring Jet-A down to a superb level.
NOTE: I'm not claiming Jet-A is the correct answer for you. I don't know your setup, engine type or emission controls. I will state that Jet-A is very stable and 'could' be an option for those needing a long storage life fuel. Store it without additives and it will last a very long time.
