Hi, All, this is my first post. . . .
I'd like some advice on the best oil to use in my diesel generator. Here are the specifics:
--Northern Lights industrial genset NL 673M with a 0.71 liter, 3-cyclinder, 4-stroke, liquid-cooled Shibaura engine.
--Operates at 1800 RPM.
--Uses high-sulfur diesel fuel.
--3 quart oil sump, oil changes at 200 hour intervals. The owner's manual specifies 100-hour changes but the dealer passed on word-of-mouth instructions that the factory had extended the interval to 200, so that's what I'm doing.
--Ambient operating temperature is in the 55-85*F range, but usually at about 65-75. Elevation is 1250 feet ASL.
--Time on the engine is just under 4000 hours.
--I have used Chevron Delo 400 15w40 exclusively in this engine. Folks around here swear by it, and it's available and cheap at Costco.
I have become convinced that synthetic oils are the best way to protect my engines, and I now use M1 in my three passenger vehicles. So now I'm trying to decide whether to make the switch to synthetics in my generator and John Deere tractor (to be the subject of a separate post).
I have some Shell Rotella T synthetic 5W-40 which I'm thinking of using in the generator. The stuff is available at Wal-Mart and it's not too pricey. Seems like it would reduce start-up wear considerably. I am open to suggestion as to what synthetic to use. Also, it may be that through sheer dumb luck that the Delo is just the right oil for this engine. If it's smarter to continue using that, so much the better.
I look forward to your advice and observations.
Cheers, Mark
Cheers, Mark
