In my 95 PSD I have been using John Deere Coolant with the PreCharged Concentrate in it, and maintained with Motorcraft FW-16. In my 01 PSD I have the Factory Coolant maintained with the Motorcraft FW-16. I will be changing to the Zerex G0-5 shortly in the 01, hopefully eliminating testing and adding SCA's.
Just for info the Motorcraft FW-16 Coolant Supplement contains Na 17,500 and K 76,700. (These analysis numbers are provided compliments of Ed Hackett, one of our members. Thanks Ed.)
I have always subscribed to the bubble theory causing the pitting of the cylinder eventually causing a leak with out the proper nitrite (NO2), molybdate (MoO4) and the proper PH Balance (all tested using the Fleetguard coolant test strips). When you don't have a cylinder liner, it is hard for electrolysis to develop where there is not any dissimilar metals, and a pin hole leak forms at a given point in the middle of the cylinder from the coolant side. JMO
[ November 21, 2005, 12:36 AM: Message edited by: 59 Vetteman ]
