I like your work and your thinking pete, I've just had a look at mine, I use a screw in bayonet adapter too and my filler has a ball bearing valve that looks like if you press in vents a couple of times then would allow me to pour in through the bayonet befre refuelling. And I agree it should give a sufficient enough dose. (I hope I haven't done any damage I assume there s a cut off valve on the entrance to the tank too)
Its difficult deciphering the msds 's isn't it, there's another Lpg injector cleaner that's supposed to work well in the UK called ic12, but I can't find what's in that. I think generally they use some sort of solvent, a light carrier oil, and any additives, I see where your coming from us PEA supposed to be the best cleaning additive I can gather from on here.
So I suppose you want the thinnest oil you can get that maybe hopefully vaporises too to go in there with it, I don't know what that mite be?
(Hence why I asked about diesel in my first post, I noticed that petroleum based baby oil is also a white paraffin type oil lol!!)
I wonder if you removed the first filter going into the vaporizer it mite actually help getting things through or cause damage or not?)
I also read a little bit more about the oily 'heavy ends' that can exist/form in Lpg already.
Raso Enterprises - Automotive Products and Information
www.rasoenterprises.com
How viscous is the TCW3 and how soluble are the oils compared to each other any ideas at all?
