Thanks for the replies and links, so TCW3 is in some way superior and more appropriate than regular motorcycle 2 stroke as a UCL in car engines?
And yes, the recommended way of 'prolonging ' valve/seat life (I don't think anythings a complete cure anyway) for some proner engines running on propane is to have a pre oiler fitted into the intake, like the ampco one earlier in the thread, to have a flashlube (yeah presumably it's a n alternative lead replacement additive in a carrier light pale base oil or something) that basically slowly drips oil into the inlet tracts.
You could in fact drip anything into there instead/as well as flashlube, TCW3, MMO, ATF, diesel, kerosene, water?
It would be good to get something onto the valves that would have a similar cushioning effect like TEL used to.
Problems are that on some engines it's more involved infusing the oil into the manifold, and some kits work on vacuum which isn't that efficient at higher rpm s when you need it and they're are electronic kits which are harder to set-up for the drip feed.
And yeah, it's when you're actually running on propane that you need it really.
At the moment, I'm just limiting my revs when on propane and switching back to gasoline temporarily during load and prolonged running for periods to keep the temperature down.
