Did they get rid of normal DOT3 ?
wa
Only DOT 3 on O Reilly's shelf is Synthetic DOT 3? And how good would it be mixing it with the normal old stuff, and what effects on the seals in all the cylinders in the system? Can't be good for the old ABS system?
Yep, brake fluid is synthesized. It is basically polyethylene glycol. It is hygroscopic but does not swell rubber. In higher molecular weights, it is a solid and is sold as Carbowax.
There is no such thing as natural brake fluid and never has been!
Some old European vehicles used a mineral oil brake fluid. Tractors and industrial equipment too. Not even slightly compatable with the normal DOT stuff in wide use today.
I meant standard dot3, if its not different some how why do they even add the word synthetic?
5K lb Hyster f lift says DOT 3 on its cap? I agree though it should just be hyd fluid.
Why would you be mixing brake fluid? A correctly functioning (i.e. non-leaking system) simply needs a flush and fluid replacement every 24 months or so.
No, that's not normal. That's just silly. The reason there is a reservoir of fluid is so it doesn't need replenishment between pad changes.
I'm not talking about large amounts over a short period of time by any means. I'm talking minuscule amounts over a several year period. I maintain my vehicles better than most (probably better than you) and prefer to maintain levels at the full mark. If you wish to just keep it between the max and min marks, then good for you, topping off is not needed.
DOT fluid is a mix of glycol ethers, polyethylene glycol and (di)ethylene glycol with corrosion inhibitors, water scavengers and other additives. When you start getting into Japanese formulations as well as Euro DOT4/5.1, borate esters are added to increase wet boiling point.
There is HSMO - used in older Rolls-Royce/Bentleys and currently by Shimano and Magura.
So then it is and was just nonsense for the outfits marketing DOT3 to put the word "SYNTHETIC" on the bottle if it was always that. All my life I never saw that on a container of DOT3, I personally thought it was some new and fancy thing they were doing now.
Just looked at maybe 3 year old NAPA DOT3 fluid jug no mention of synthetic on it.
Nothing on these Honda bottles mentions synthetic.
https://www.collegehillshonda.com/product/08798-9008.html
Sorry to a person like me and likely others that are into details, it just didn't and does not make sense, to add that to the label if it is a nothing burger.
Sorry not all of us are Brake fluid chemists. I've just always hated the stuff.
Not totally true. It is normal to add small amounts as the brake lining material wears and gets thinner.
Well us non internet mechanics of the 1960's, would go Hmmm sometimes 6 plus years or more, and never change the brake fluid, and only do so when it leaked some place, like a wheel cylinder. And then only enough to fill up that replacement wheel cylinder. Yeah the good old days, especially for us poor highschool kids, with only pennys to buy parts with. :ROFLMAO: :ROFLMAO: :ROFLMAO:
Then why are dealers and parts places selling little tiny bottles of brake fluid? Please with all the wisdom, explain that?
Only shops are required to change fluid or lie about it between brake frictions replacements.
I've always gone untold years and not changed brake fluid. If it wasn't for dealing with a booster issue on my one car, it would have 70 plus some k miles and 25 years on the original brake fluid, and all is good, go figure. That was about 12 years ago, but then the front pads lasted and still had a bit of meat at 70K so?
