- Joined
- Dec 28, 2014
- Messages
- 2,846
Before I go and bash these products let me just say, I get it. I think everyone should do what they feel is best and if it makes you feel good, do it. Do it. Absolutely, because at least you’re showing pride in ownership and in the long run you’ll end up doing something that will help your vehicle over the course of its life. But this isn’t it.I highly doubt this does anything. I used this before I took my manifold off and it still was absolutely full of gunk.
I’ve done the same, it did basically nothing (Taking my manifold off expecting to see some form of sign that my treatments with CRC did something).
And when I discovered THAT, I did a little “test” of my own on CRC cleaner. I had a carbon coated valve laying around in the shop (nothing too bad) and sprayed an entire can DIRECTLY on the valve. Nothing. So then I let the valve soak directly in a solution of sea foam for two hours. Nothing. I then unloaded another half a can directly on to the valve AFTER heating the valve up to 200 plus degrees and next to nothing - as I continued to spray the remainder of the second can. Oh and I also agitated the valve back and forth in the solution while it was soaking for two hours.
And the before and after photos, videos, scopes, whatever with these products need to be compared to whatever would happen with untreated valve/combustion chambers. Because gasoline, heat, combustion take place and things will change. These YouTube videos generally show what it looks like after treatment (which usually is next to nothing). Show what happens while using nothing at all, I imagine it’ll look remarkably the same.
I think the only way these cleaners would “work” is if they were sprayed once a week, or more.
