Did my oil filter tear?!
Originally Posted By: RegDunlop
Last OCI ( about 1100 miles ago) i used Quaker State Ultimate Durability and a purolator classic
I hadnt been reading BITOG RECENTLY SO i did not know the issue with purolator filters tearing.
It seems to be consensus that they tear in the first 1000 miles.
Would I be able to tell if this occured?
How bad is this if it happens?
Should I dump the oil right now and replace the filter?
Remove it and don't worry about it. Basically any other major filter will hold up better so why use a purolator?
I had back-to-back failures at about 3,700-4,000 miles and 3,010 miles by the time I changed my oil. Statistically, those chance of getting a bad filter should be so low that it might as well be that it should not happen... ever. Some filters seem much more likely to fail, look at the spread sheet as a few part numbers account for most failures... but these are also for vehicles with higher production numbers.
As far as when they tear, that is a bit of an unknown. It is not a long distance, but I cant say if it is 1000 or mile 1. I can say that it fails while the oil is still effective. I think that the higher oil standards have been saving purolator on this.
Originally Posted By: Cristobal
Hey, does anyone know what percentage of Pure Ones were tearing? I have one from 2011 production.
We don't have the best picture about the failure rates. My guess it that it is at least as high as 1 in 3 spin-on filters.
It should be less than 1 in 10,000 (or 99.999%). Considering that BITOG has 70+ filter failures, if the failure rate was 1 in 10K, then BITOG had to open up about 700,000 filters to be "normal". However, just my eye-ball inspection of purolator cut-and-post makes the failure rate seem closer to 1 in 3 or even 1 in 2 of purolator posted here.
So even if 1 in 100 filter are failing, you would see 7000 not-torn pics/posts on this website.
Anyone understanding cluster statistics should realize that 70+ filters failures in a small population is significant. How did you think they realized something was wrong with GM ignition or Takata airbag? Did they test every one? No. You just need a small sample to see if something is not right.
Originally Posted By: ZeeOSix
^^^ Definitely! As I've said many times, I could care less if someone uses filters that tear or even destroy their engine for some reason. At least if there is info for someone to decide, then that's about all anyone can go by.
You mean couldn't care less? LMAO
Why so many posts in this thread if this is truly the case?
Originally Posted By: NoNameJoe
Looks like the Purolator shills are out in full force. Change the filter. Don't take our word for it, even Purolator says you should change their garbage filter:
http://www.purolatorautofilters.net/news/Pages/OilFiltersWhyFailureIsNotAnOption.aspx
Quote:
The consequence of a clogged oil filter is typically the routing of unfiltered oil to critical engine components or, in extreme cases, total oil starvation. In either case, “the result is damage to engine bearings and other precision engine parts, greatly shortening engine life,” he said.
Is that "scientific" enough for the paid shills? I mean if it came from the keyboard of the Purolator paymasters and their fear-driven "YOUR ENGINE IS GOING TO BLOW UP UNLESS YOU USE OUR SUPER DUPER FILTERS" agenda I guess it's fine but when it comes from real people with no agenda other than wanting real filtration having paid money for it, any attempt to warn people away is not fine; nor are user-generated reports about the issue. Nobody takes you guys and your ridiculous trolling as anything but trolling. You guys can't be serious.
Quote:
Just recently cut it open after it sat outside for a year and a half. It looked great.
Yeah so was the first one I ran. Then the second one was torn rofl. I don't get what this was supposed to imply when there's a whole spreadsheet of people who ran into this issue? That the issue doesn't exist? That you might get lucky? Cool. That would make the op feel better. After reading this he now knows that it might be torn.
Yawn, another Fram fanboy.
Good point.
Good point.
Just giving the OP info so he can make a sound decision. I think having data showing this is not just a freak rare occurrence is better than saying "Hey man, you have nothing to worry about, just use them" like some guys here recommend doing. It's not like Purolators are the only oil filters in the world. I usually don't go using products I know that are having reliability issues. If others do, then no skin off my nose ... that's their decision.
LoL ... That's a good one. So recommending using oil filters that have a good record of tearing isn't?
I thought everyone already had their FRAM Ultra inoculation.
Does that mean we all have to get back in line for booster shots?
There was a time, not so long ago, when you could easily spot a bad oil filter by its orange can.
Good point.
yeah, wopners at 4:00. I buy my underwear at k-mart.
Times change and the Ultra is definitely not in a class with an Extra Guard or a Tough Guard for that matter.
I hear those tear pretty easily ... especially if you put too much debris into them or cause too much delta-p.
Some people can't get past brand name blindness or fanboyism. I like to judge a product for what it is, not for what I think it should be based on the brand name.
It's not uncommon for brands that have gotten a bad rap in the past to put out a stellar product later down the line (Ultra). And it's not uncommon for a stellar product to fall to the wayside due to a change in quality (Purolators). Both of those things have happened on this chat board in the last 1~2 years. Some see it, others are blind.
If it's a 14459 or 14610 made before December 2014, it tore (those two filters are the worst for tears).
If it's made December 2014 or later, it's probably safe
Also, the synthetic PSL filters do not tear regardless of manufacture date.
....yeah, wopners at 4:00. I buy my underwear at k-mart.
And that would be the kmart at 400 Oak Street Cincinnati, corner of Oak and Burnett. 2 minutes to Wapner. Hey now, hey now.
You are basing that on what exactly?
Wishful thinking?
FRAM Ultra vs Purolator Classic?
Ultra just proves that even a lousy filter manufacturer can build a good $9 oil filter.
There is no problem with tears with either of Purolator's premium filter products (Purolator Synthetic and Bosch D+) either.
The FRAM OCOD is comparable with Purolator Classic and its track record with low pleat counts and sparse, decontented design is just as flawed as Purolator's entry level product.
So who is blind here?
No, more like Ultra vs PureOne ... both high efficiency. PureOne is not reliable as evidence has shown, it loses.
Purolator just proves that even a good product can go down the tubes when quality suffers.
True, stick with a synthetic if you want to use a Purolator made oil filter.
Not quite as flawed ... as it doesn't tear media. Still blind.
Sounds like you are going to stay that way.
The lesson I see here is to buy NAPA Silver or O'Reilly Microgard if you want a solid, inexpensive oil filter.
Using Wix/Microgard on the Camrys right now, OEM Toyota on the Land Cruiser, Bosch D+ on the Mazda, and Mahle built OEM BMW filters on all the BMWs.
