Originally Posted By: Tegger
Originally Posted By: Carnoobie
I know it puts more wear on the engine but i was told its very minimal cause from what i notice it only spins 1000rpms higher than normal while in 3rd doing about 50-60kmh.
"Only" 1000rpm? That's about
60% higher. That's almost two-thirds more wear, which is not "minimal" at all.
And, if I were you, I'd skip that LubeGard thing. Up to the '05 model year, Honda had terrible problems with many models' automatic transmissions. It cost them millions in warranty claims, and untold amounts of reputation-damage. At great expense and effort, Honda has since fixed this, and now makes what are probably the most reliable automatics on the market. It's pretty safe to say that Honda knows exactly what makes their transmissions work well, and what does not.
It is unwise to use anything but genuine-Honda ATF-DW1 in your Honda automatic, and you should definitely stay away from any and all additives; Honda takes a dim view of additives.
Well the reason why i reason i use D3 a lot and manually shift to D (to get into 4th) is not so much to minimize the shifting but cause i have a 200rpm flare everytime when trans is hot, shifting from 3rd to 4th. But only happens when shifting between 2000 and 2800rpms. Anything under or over and doesnt happen. It has to do something with a valve pressure problem.
Ive driven with it for months, in D all the time, but for the most part would intentionally back off my gas each time as its about to shift to 4th between 2000-2900rpms to avoid the flare. But i got so sick of doing it cause its a major nousense like you wouldnt believe. So buddy mech one day told me to keep it in D3 and manually shift. He said it wont hurt the trans by manually shifting. And that its no different than the computer automatically shifting.
So one day i tried it, figured out which speed i have to hit at the minimum before shifting to D to get the trans to shift to 4th right away and its 60km/h. I do this and the trans shifts smooth and right away each time with no flare at ANY rpm.
Watch this to see what i mean for the 200rpm flare when in D going from third to 4th between 2000-2900rpms (20-22sec mark). Turn up your sound.
http://www.youtube.com/watch?v=XadCsC5a3_M
Trust me ive asked my buddy mech abotu the extra wear on the engine and he said honda engines last a lifetime anyways and are the best engines in the world, its not going to significantly wear it out faster. Thats just what he said.
And mind you another thing is that Im a grandma driver. I pretty much never take my car past 3000rpms. So even though my car is running at 1000rpms higher when in 3rd doing between 45-60km/h, i dont know if that would be more wear on the engine in the long run vs someone who drives their car in the 4000-5000rpms range all the time. Hope its not confusing.
