Did I drain my FF too early?
"In the last few years--maybe 5 or so, there is no evidence of extra moly in Honda/Acura new car used oil analysis. Maybe the anti-wear agents now being used are not visible in a traditional UOA"
For US made vehicles that's true. Any vehicle made in Japan gets the moly oil from Idemitsu. As Honda is concerned, I don't know which of any models are still imported. Mazda and Mitsubishi are totally Japan made as are some Lexus models and the Toyota Land Cruiser if I'm not mistaken.
Yep, the oil you dumped was probably better than what you refilled with. Honda puts a special moly conditioner in the oil when the vehicle is new.
Originally Posted By: mightymousetech
Originally Posted By: roadrunner1
While most manufacturers don't use anything special for the FF the assembly lube DOES have the extra additives needed for a proper break-in. I'm in the camp of leaving the FF in for the owners manual recommended interval, you can't go wrong following the owners manual.
Just for FYI. Honda/Acura state exactly this. We actually had a service bulletin stating that doing the first oil change early can actually damage the motor, causing hot spots on the wear areas because the additives that prevent friction during break in will be drained. I am assuming this is moly from the assembly lube.
Whether it's from assembly lube or add packs, upwards of 500 ppm Mo it has.
well shoot...my 09' civic which I had for 5yrs didn't have any issues...my 03' accord nope none either, and my current 17' civic nope know issues yet. All FF changed out with 1000 miles or less...
Originally Posted By: Trav
You did well getting it out early, the oil is not a high moly oil neither is the one Honda uses it is moly paste residue used on the bearings to prevent dry start when it was made. Its easier for them than priming the engine.
Once the engine has oil pressure this compound is doing very little as far as additional wear protection goes, rogue metallic particles are possibly doing more harm than the moly is doing good.
Sleep well, you did not harm.
Ditto...
Originally Posted By: aquariuscsm
Heck,if you still have it,you can always pour it back in :^)
Mixes well with whiskey
