Di-ester booster
Kuwait
I was checking out the spec sheet for Castrol EDGE 10W-60, and it mentions having a 'di-ester booster'. I've done a web search, but couldn't exactly get what I was looking for. In simple terms, what is it's function in motor oil and what makes it worth having in its composition? Thanks!
Here is a patent concerning diesters. http://www.freshpatents.com/Diester-base...20080194444.php
Quote:
BACKGROUND
Esters have been used as lubricating oils for over 50 years. They are used in a variety of applications ranging from jet engines to refrigeration. In fact, esters were the first synthetic crankcase motor oils in automotive applications. However, esters gave way to polyalphaolefins (PAOs) due to the lower cost of PAOs and their formulation similarities to mineral oils. In full synthetic motor oils, however, esters are almost always used in combination with PAOs to balance the effect on seals, additives solubility, volatility reduction, and energy efficiency improvement by enhanced lubricity.
Ester-based lubricants, in general, have excellent lubrication properties due to the polarity of the ester molecules of which they are comprised. The polar ester groups of such molecules adhere to positively-charged metal surfaces creating protective films which slow down the wear and tear of the metal surfaces. Such lubricants are less volatile than the traditional lubricants and tend to have much higher flash points and much lower vapor pressures. Ester lubricants are excellent solvents and dispersants, and can readily solvate and disperse the degradation by-products of oils. Therefore, they greatly reduce sludge buildup. While ester lubricants are stable to thermal and oxidative processes, the ester functionalities give microbes a handle to do their biodegrading more efficiently and more effectively than their mineral oil-based analogues. However, the preparation of esters is more involved and more costly than the preparation of their PAO counterparts.
Quote:
BACKGROUND
Sounds like they just described Auto-Rx! IMOP
