I can find lots of talk on specs and reverse compatability but not much on folks having actually used it in an older application and maybe more importantly to me in a performance application.
I am thinking maybe I would go out on a limb and try the Dexron VI in my car and am hoping to get a few comments and honestly hope Terry and Mola in particular pop in. One thing attacting me is it is easy to find as a local GM dealership.
Application is a 96 Caprice 4L60E with roughly 400 RW hp
. Car is roughly 4250lbs with me raceweight(mostly drags plans for some AutoX), 4400 daily driver weight and I do drive it a lot.
Tranny is built to take the punishment, has a 3400 stall small diameter lockup torque converter heat is not a problem despite what "conventional wisdom" would suggest.
I spoke to the tranny builder and his only reservation was he was not sure about it's reverse compatability but it sounds as if that is not a problem???? He recommended Monolec 1150 and I will take it into consideration if you guys think the Dexron VI is not a good choice. Other considerations are Specialty Formulations I ran out of this but liked it, went back to order and he doesn't list Dexron anymore though being the great vendor he is though I bet he would work with me, and I was thinking maybe Shaeffer's might have something to offer.
At one point I had M1 in here and that di not work out well some guys are finding that this tranny under performance use does not like full synthetics
I really would like to have something I can get locally but if I need to go with something more exotic I will just make sure to always have at least a full extra fill onhand something I had failed to do when I bought the Specialty Formulations last time and because of it there is Walmart stuff in there now
it is working but I know I can do better.
