I had my tranny rebuilt by a performance builder about 4 years ago and at the time he was able to get Dexron IIe. I now need to drain and refill my 4l60e and can no longer get it. I contacted him and was advised to use Type F as it is a non synthetic and contains zinc which he feels is more compatible with the type of clutches used in the rebuild. The reason he does not recommend the Dextron 3/Mercon is because the main lubricating component, Zinc has been removed from this type of fluid.
Is it true that zinc as an additive is not used in Dex 3/Mer?
Is Dex 3/Merc a blend of syn and dino?
