Well one thing is for sure; Dex-Cool and G-05 are better than the old green conventional engine coolant. I believe Mercedes has used G-05 since ~1984. GM has used Dex-Cool since ~1995.
Conventional green engine coolant has silicates and phosphates. Dex-Cool doesn't have these. G-05 has a very small amount of silicates. Silicates protect surfaces very quickly. The organic protectants take time to start coating the inside of the cooling system, but once this layer of protection has formed, it appears to work quite well.
The Mercury Cougar used Dex-Cool from 1999-2002 when the Cougar was discontinued. This is documented on page 72 at this link...
http://www.fcsdchemicalsandlubricants.com/fad/pdf/catalog.pdf
Both Dex-Cool and G-05 are marvelous formulations. This idea that GM switched to Dex-Cool to screw their customers over on cooling system repairs is stupid. I am pretty sure all manufacturers add the protection tablets at factory-fill.
GM and the other American auto makers knew that the time had come to switch from the conventional green engine coolant they were using up to ~1995 due to consumer demand for a longer life engine coolant. My guess as to why Ford and Dodge use G-05 is probably due to licensing & money. Why should they pay GM for their engine coolant? I would bet Zerex cut them a **** of a deal on G-05.
I don't think Dex-Cool eats gaskets. A lot of the 4.3L engines used in the S-10s had crappy plastic head gaskets that were accidentally over-torqued at the factory which caused them to eventually crack. There may have been a recall (I cannot verify) on these head gaskets which are suppose to be metallic now. You can even use Fel-Pro gaskets which I believe are made out of cork.
Another thing on the S-10s was the original radiator cap. They use the weighted close/open valve design radiator caps. Stant makes the 10320 radiator cap which uses a spring-loaded valve. It is a vastly superior design as compared to the factory one and costs about $4 at any Advance Auto Parts store.
It only takes about 20-30 seconds to check your coolant overflow tank to verify it is at the required fill level and then to take off your radiator cap to verify your radiator is also full of engine coolant then to put the radiator cap back on.
For my family's GM vehicles, I like to use the Zerex 50/50 Dex-Cool for top off if needed since it is mixed with distilled water. Since switching my 1998 Ford Mustang GT to G-05 over 6 months ago, it has NEVER needed to be topped off with more coolant. I do have a 60/40 mixture of G-05 and distilled water both in the Mustang and in a left over G-05 engine coolant jug. I think the coolant is only as good as the water used so I use distilled water with my coolant.
My only complaint about G-05 is that it is so clear-colored. I wish it was dyed green since Zerex claims it is the direct replacement of conventional green coolant.
I think Ford uses a more intelligent design in regards to combining the overflow tank and the radiator (overflow tank being only way to fill the radiator as well) as compared to GM which uses a separate overflow tank which has a cap to fill it connected to the radiator through a small rubber tube with the radiator also having a cap to fill it. I am basing that statement comparing my 1998 Ford Mustang GT to my family's GM vehicles which are a 2003 Chevy S-10 and a 2004 Chevy Blazer.
