Originally Posted by stockrex
Originally Posted by LeakySeals
Also I saw on the list you may have rust poking through the GM frame wax. What you want to do is scrape away the wax around the rust spot. Give it a good clean with a wire wheel some grinding or a little sandpaper. Then cover it up with corroseal. And cover with NOX-RUST X-121B from Daubert. It's the factory wax in a can
So that is what the peeling stuff is, good info, I thought it was some sorta paint peeling.
Clean brush sand > reapply corroseal
I have the stuff peeling big time under the doors, scrape off with a putty knife?
Yes that's the basic procedure. You don't need to remove all the rust just get as much as you can. Then paint the corroseal on with a brush or tiny roller whichever you prefer. Then smother with NOX-RUST X-121B from Daubert. What I see in your pictures is an inferior wax job versus other years. It's just not thick and not adhering to the galvanized surface underneath. So you might as well spray large areas and thicken it up. It's an easy-to-use product that doesn't drip it like foams up very strange. I'm using all three of these in different ways.
