Detroit Free Press: Class action sought over Dex-Cool
Kestas
Staff member
The Motor City
Article
I thought this article may be of general interest.
I noticed the article doesn't explain why some Dex-Cool cars have this problem, while the majority don't.
If the judge rules that DEX-COOL cases can proceed as class action suits, it would likely follow during trial why the problems primarily occur with certain engines, and, at that, certain engine components - especially if Chevron Oil Co. (Texaco's parent - Texaco supplies DEX-COOL(tm) to GM as factory fill coolant.) is called as a material witness. I suspect once that happens, a number of contingency sharks slathering over the prospect of multi-million dollar awards will find themselves set back on their cans. I'm not a lawyer, but if I were, I'd be looking at the angle of the harder to defend GM decision to use expansion-limited plastic intake manifolds mated to expansion-prone aluminum cylinder heads.
Ray: I agree with you--the problem is poorly designed i/m gaskets (poor engineering) and not the fault of Dexcool. The only thing about Dexcool is that when your cooling system runs low on coolant (and air enters) it turns to mush.
The (poor) design of the 3.1 and 3.4 V6 plays a
part also. The design engineer should be shot.
What's the big concern, guys? Didn't you read the last quote from GM in that article:
"The first priority of General Motors and its dealers is helping our customers," Lama said.
Every company makes engineering mistakes from time to time. The issue here is that GM knew of the manifold problems for almost a decade and knew a way to fix them existed, but just didn't bother. At that point you can't really blame the engineers. The accounting guys are the ones behind this.
It's the gaskets!My fathers' 84 GMC,my 85 Chev,my sisters 86 Chev truck all leaked coolant into the engine from the intake gasket....and this was with the green coolant...so now what.G.M's time for reckoning is near...there are alot of cheesed- off customers out there!
jsharp: You are right of course. The accounting guys probably never figured that people would
'communicate' via the internet about how widespread the problem was.
