This may be one for the tribologists here. I recently had to replace the blower motor resistor in my truck. So now it moves a lot more air with more velocity thru the AC and defroster vents. That was earlier this summer when the temp control was always on maximum cool or not too far from it. Everything was fine this past summer.
Now it is getting cold here and I used the heat/defrost setting this morning for the first time this season. I live in Florida so "cold" means it was about 55 degrees this morning on my way to work. Anyway, with the fan setting on its second lowest speed and the temp selector in about the middle between cool and warm, there is a whistling sound from the top center windshield defroster vent. If I leave the fan on the second setting and move the temp selector a few degrees one way or the other, the noise stops. If I put it on the lowest fan speed the noise stops. Of course if I put the fan on high speed I hear no noise. The heater function in my truck is set up so that a minimal amount of air comes out the defroster even when the full floor heat is selected on the dash control panel. I get a little air out the defrost on AC and dash vent output too.
Anyway I am wondering if any BITOGer's have any idea on the whistling noise. I looked down the defroster vent and saw no obstructions or anything else to cause the whistle. I wonder if "warm" air exiting the defroster vent moves slower and the air on the middle temp setting is moving at just the right speed and temperature to make this noise?
Any help here is greatly appreciated.
