2008 Suburban LT 1500 5.3L with 129K
Second time in three days this has happened: Cold vehicle (24 degrees out this morning), turn on front defroster (from the bi-level setting) and there is a small but audible grinding sound coming from in the dash, and defroster doesn't doesn't blow. Then, a few minutes later, out of the blue, it starts blowing as it should. It worked fine the rest of the way in to work.
My immediate remedy is to just leave it on the defroster setting at the end of the commute home, and see if not asking it to switch to defroster mode when cold will make it work as it should immediately tomorrow.
Obviously, something underlying is causing this. Any ideas what I might need to replace? Thanks.
