so when i bought the 93 f150 each vent selector worked. defrost mix max ect.....well today i turned the ac on and it will only blow on defrost..... heat and ac still work fine so the little arm under the dash that mechanically pulls on the vacuum operated thing , well i unhooked it and manually move it and itll go from defrost and vent fine like that also on ac setting it recognizes the need to run compressor and does so . so the switch at the dash is telling the computer to actuate the ac compressor. but it wont switch vent settings. on the mix setting i can hear a clicking noise . i think its coming from the firewall area. can anyone make sense of this?
