So let’s posit this out since I don’t think it’s been discussed in complete depth. Technically if all the louvers were closed, delta-p would be zero, but the bypass would obviously lift. Then, since the pressure sensor is downstream of the filter, and flow is obviously greatly reduced (no way a bypass flows as much as the center return tube or the total inlet area, right?) and the BPV is acting like a Venturi, one would see a reduced pressure if an actual gauge was in use? Or do regular PD rules still apply even with the total bottleneck of the BPV being the only source of downstream flow? If somehow the BPV could handle 100% of flow then obviously regular PD rules still apply. I’m just not sure if filter makers size the BPV to be able to handle 100% of flow at all pressures.
Did I get it right?
