I searched but didn’t find this being discussed before.
It is hard to believe the voters keep reelecting them as they destroy our nation and bankrupt it.It's hard to believe that politics has found a way to force manufactures to introduce cow pee into Diesel engines for, "the good of mankind".
Saving the planet one plastic bottle on the side of the road at a time.It's hard to believe that politics has found a way to force manufactures to introduce cow pee into Diesel engines for, "the good of mankind".
It does legitimately easily reduce harmful emissions. The poor implementation is the problem though.Saving the planet one plastic bottle on the side of the road at a time.
Yeah water it down.It does legitimately easily reduce harmful emissions. The poor implementation is the problem though.
While urea is a fertilizer I would think using liquid urea would burn the lawn badly. When they use it on corn it is encapsulated so it doesn’t damage the corn till it can get into the roots.
Where do you find Ammonium Nitrate fertilizer? It's nearly unobtainable in Michigan due to it's explosive uses.I'll stick to applying Ammonium Nitrate to fertilizing my yard.![]()
Dollar GeneralWhere do you find Ammonium Nitrate fertilizer? It's nearly unobtainable in Michigan due to it's explosive uses.
I think Family Farm and Home sells itDollar General
Lowes carries it.Where do you find Ammonium Nitrate fertilizer? It's nearly unobtainable in Michigan due to it's explosive uses.
Even better, without salt.DEF is just concentrated pee, so why not?![]()
