deeply recessed valve stem - another automotive engineering marvel.
Mercedes sells a special impact gun socket for the valve stem cover. It’s only $499.99, what’s the big deal?
That was 2019 pricing, it is now $699.99 and they don't stock them. Needs to be shipped ground only for some reason, and they tag you $39.00 to ship it.
Wow! Are your fingers really that fat?! That doesn’t look to be very tight. Pictures can be deceiving though.
I guess I get it, I’ve seen guys with hands that looked like stumps with 4 Brats and a Vienna sausage hanging off of them. 🤔
This is why I always got to do the work that required a little finesse and finger dexterity in tight spaces.
It's only got about 3/8 inch on each side of the plastic cap.
Don’t take my post the wrong way, I’m only ribbing you a bit. 😉
You did say that you had “fat fingers” though. 😀
Using a piece of hose was a great solution. There’s always a way. (Once you stop cussing the manufacturer and think about it for a moment.) 😂
Ya well as I age all of me is getting fat!
Yep, I’m finding that my body’s fighting me at every turn now that I’m in my mid-50s. Staying in shape and crawling into tight spaces is getting a little harder.
We take things for granted when we’re in our 20s and 30s. 😉
That spot in my socket rail appears to be empty ?
Maybe @Pablo can hook you up. https://www.amsoil.com/p/emergency-10mm-socket-set-g3884/
But seriously they sell them as kits for a reason. The 10mm struggle is real. Husky 10mm socket set
I once owned an Elantra Sport sucky like the Mercedes wheel pictured. The valve stem is between and below the narrower dark grey spokes, look at the 4 o'clock position. I added the stainless steel tire pressure caps you see on semi trucks which made it forever easy peasy to check and add air.
