That’s not how that works.That's how every OEM does it. They punch in the failed part # and the software tells the advisor if it is a covered part.
Go on...That’s not how that works.
Sounds to me like they want to sell you a brake service. Just say no thank you if you don't want it?wants to charge an hour for a brake service
A grooved appearance of a brake rotor is a normal consequence of wear. The pads have worn into a matching grooved pattern and stopping performance is not affected.they've become grooved at 10k miles
Just tell them you want replaced only whats under warranty. You might have to talk to the service manager or call Hyundai corporate. They can't make you pay for new pads, especially if they aren't worn out, and on an EV, they should go over 100,000 miles.Our '21 Kona EV has bad rear rotors. The pads aren't making contact and they've become grooved at 10k miles.
The dealer is replacing the rotors under warranty but wants to charge an hour for a brake service.
I'd rather pay for a couple hundred dollar pipe than a couple thousand dollar engine or transmission.I'm an owner so I canIt is a nice long warranty but there are huge holes in it.
exhaust rusted out 3x at the front clamp on the 2010 accent... wasnt covered because pipe wasnt covered.....
but that being said if you make it to year 7 and the engine or trans implodes ... nice that its still covered.
Thanks guys.
I may just have them swap the rotor and do the service myself. I'm sure it's not due until 24 months.....and even then, we're talking about lubing calipers. The rotor and caliper are already in their hands, it's essentially paying an hours labor for 2 minutes of work. Lol.
This here... Based on my experience if the Service Manager is any good if they charge you for the initial brake takedown and you agree to it they should comp the labor for the pads once they find the real problem... Warrantying out the Rotors isn't going to fix this problem....I don't think the rotors are causing the issue you describe, unless they are made from soft material. That should be a known issue if that's the case.
In my opinion, the problem has more to do with the calipers or the emergency brake.
I'd find out what they were going to do if either of those two items are causing this. I'd think in any case a problem like this should be warrantied.
I know, they always get you with that "wear item" line, but this is way too soon. Especially if the fronts are normal.
Have worked at Honda, Ford, Toyota, VW, Mazda, Kia and BMW as a tech. All manufacturers are a little different but the same. Ford is the one that’s very different. When a diagnostic takes place under warranty, the car is scanned for DTC’s if applicable. If it’s say a wheel bearing and the vehicle has not been tampered with meaning any suspension changes, level kit, lowering kit and the vehicle is inside of bumper to bumper warranty or time, once the determination has been made it’s for sure the wheel bearing, the technician then goes to parts, gets the price of the wheel bearing, bolts, and etc, looks up labor on all data then turns in the RO to the service advisor. You explain your findings and the advisor then has the build date and the purchase date of vehicle to make sure it’s inside of warranty. He gives the okay to replace the bearing and bolts. The old parts have to be saved, as ford can ask for that part back at any time. if one bolt is missing, ford will kick the warranty claim back and not cover it. Now if it’s say an engine that is messed up, ford wants the technician to find the failure meaning disassemble the engine until problem is found. At that point, the service manager is called out to look at the damages, if it is determined it is a manufacture defect or another part caused the failure and the vehicle is factory meaning not been tampered with, the service manager then makes a claim with ford over the phone, they discuss the issue and the ford rep says if it’s covered or not. Only big repairs have to be approved through ford, engines, trans, rear axle, front axle, etc. now where it gets sticky is if the vehicle has been tampered with, say a powerstoke. The first thing that is looked at is the PCM. The tech looks at all the data in the PCM to see if altercations have been made. Most people think if they plug a tuner in and reprogram the PCM and then put it back to stock the dealer can’t see that, we’ll we can. We can see past codes that have been cleared, all the changes the programmer did, how much boost and timing the engine was at when it failed, it shows all the parameters.Go on...
Right, which is more or less what I was referring to. During the verification process, the Service Writer has to verify that the part is covered under warranty. Often times, this involves entering the part # of the part into a system that verifies warranty coverage.If it’s say a wheel bearing and the vehicle has not been tampered with meaning any suspension changes, level kit, lowering kit and the vehicle is inside of bumper to bumper warranty or time, once the determination has been made it’s for sure the wheel bearing, the technician then goes to parts, gets the price of the wheel bearing, bolts, and etc, looks up labor on all data then turns in the RO to the service advisor. You explain your findings and the advisor then has the build date and the purchase date of vehicle to make sure it’s inside of warranty. He gives the okay to replace the bearing and bolts.
My experience with Ford is it's generally DESIGN error!With ford warranty they are always looking for a way not to cover something. They are always looking for an operator error.
We had extended warranties on the co. E-vans years ago-foolish people didn't read the fine print that commercial use wasn't covered! So the warranty worked perfectly-spent a bunch of $, got NOTHING covered!Consumers don’t truly understand how warranty works, especially extended warranty until something happens and realize it’s not covered
Extended warranty doesn’t cover amenities, it only covers necessities. As well as commercial not covered.We had extended warranties on the co. E-vans years ago-foolish people didn't read the fine print that commercial use wasn't covered! So the warranty worked perfectly-spent a bunch of $, got NOTHING covered!
Not everything is bad on them.My experience with Ford is its generally DESIGN error!![]()
No! There is no software that does that. All RO’s are done through ADP. It’s a phone call made. If the vehicle falls under the 3 years or 36,000 mile bumper to bumper small items don’t need verification to be replaced.Right, which is more or less what I was referring to. During the verification process, the Service Writer has to verify that the part is covered under warranty. Often times, this involves entering the part # of the part into a system that verifies warranty coverage.
I think we might be talking about the same thing in different ways.No! There is no software that does that. All RO’s are done through ADP. It’s a phone call made. If the vehicle falls under the 3 years or 36,000 mile bumper to bumper small items don’t need verification to be replaced.
