I'm not sure, but I called 3 or 4 different dealers in the area and the prices all varied. Between the highest and lowest it was about a thousand dollars difference, which I was surprised by.Keep in mind the Prius C uses a nicad battery pack instead of a Lithium ion battery pack. Maybe this is part of the cost as cadmium is really toxic and I'm sure fairly expensive to recycle.
I brought it in specifically and only for that though.The trans oil change may have been forgotten by accident, since they rarely change the fluid? Not a big deal I guess for that transmission, but shows that even charging premium dollars, it doesn't always buy premium service.
As for dealers overcharging for things like batteries, that's their business decision, as big numbers like that can either sell a new car, or make lots of money, or send the customer away. I think dealers sometimes get stuck having to use overpriced parts, or use the full complicated procedure which requires many other new overpriced parts?
Probably finding a knowledgeable independent toyota hybrid specialist would be the best for your battery swap? Or DIY if you can get comfortable with that. I think that era of battery can have individual cells replaced even, a dedicated Prius forum should have all the info you need.
That's the plan from here on out for sure.They may have not changed the fluid.
I would have waited till warm spring weather and change it.
I don’t want anybody touching my car.
The OP did not claim dealer dishonesty or shenanigans. He in fact asked of anyone has heard of such things and commented that he had. I read his post twice and could not see where he claimed the dealer was dishonest. Did I miss that somehow?I don’t think you have any reason to doubt that the work was done at 175k. By the time the transmission got to you at 221k, it was far more worn and degraded than it was at 100k. Love that you are keeping this car going, but maybe a little perspective: it’s the cheapest Prius, well into its second decade, with high miles and failing batteries. I assume that the transmission is working okay and don’t see why you are claiming dealer shenanigans that happened years ago (most likely did not happen imo) when the real questions are whether you invest more in this aging sled.
Exactly, yet the fluid was ... "recently changed it again at 221k, and it was black/super dark". Transmission fluid stays clear once the transmission is broken in and not overheated.What wear material? This transmission has a couple of gears and no planetaries nor clutches.
Every other engine oil change until the fluid and magnets stay clean. Once the gearbox is broken in, AND clean, the fluid will go a long way, maybe even as long as the mfg recommended service. Running a transmission with dark fluid (grinding compound) is never a good idea.That seems a little overkill seeing as how robustly built and durable these transmissions are and how easy they are on fluid. There are reports of people going 200 to 300k miles on the original fluid. I would never do that, but every other oil change seems excessive. ...
I took my cues from the OP and the title of the thread : “Dealership shenanigans.” I also note that he said he would not take the car to that dealer again. I think that the post leaves some doubt, and most responders, including me, suggested that nothing dishonest or underhanded happened. I would allow that it might have happened. In response to your comment, I would say that the original poster might not be making an accusation, but very much is thinking out loud that he may have been a victim of shenanigans. Does it make a difference at this point ? Probably not.The OP did not claim dealer dishonesty or shenanigans. He in fact asked of anyone has heard of such things and commented that he had. I read his post twice and could not see where he claimed the dealer was dishonest. Did I miss that somehow?
Agreed. I may have added too much in my interpretation of your comments. On the high mileage comments, I wish you and your spouse many more safe and reliable miles in this car. In my travels, including a Midwest city that has a mostly-Prius fleet, I see 400-500k taxis frequently, and you can be certain they have lived tougher miles!The transmission is doing fine. I only changed it this early for peace of mind having seen some people speak about Toyota dealer shenanigans in relation to trans fluid.
Like I said to the previous poster, this car may be only be between 1/2 to 2/3rds of its life. It's running great and has been a fantastic, low maintenance, lost cost, high MPG car. Also, not my car and not my decision. My spouse loves her car and plans to drive it till it dies/needs to be replaced.
Btw, I was not claiming that there were definitely dealership shenanigans, I was only wondering out loud if there could be based on some observations of self and others. Big difference. I do generally practice, or try to, innocent until proven guilty.
