Dealer doesn't recommend filter change Nissan Frontier 9 speed
All of those filters are absolutely changed on an hourly schedule per the -6, They are also changed and inspected when the deferential pressure indicator is extended. Maybe you worked on prototypes in the 70s?
Probably so. Engine shops job. We never touched them as crew chiefs (knuckle draggers).
I know this is a Mercedes designed transmission but Nissan I don't think has every recomended filter change on multi speed automatics (non CVT). I have one in my driverway with 420K miles nothing but fill and spill every 30K. Second in driveway with 230K only fill and spill. It depends on the transmission / filter.
What does the manual actually say?
I would maybe get a new filter and peer inside with a borescope or something. If its simply a mesh screen I would not be in a rush?
Yah know after I take a shower I still change out my underwear!
If your underwear were made of a thin mesh material with 1" holes, you probably wouldn't bother.
Most OEM transmission filters (the typical ones, of which I speak) are nothing but rock-catchers. They are so porous it's laughable. They are they just to prevent large chunks from being ingested, which is kinda moot because if stuff that big is in the fluid, it's already too late ...
The greatest risk a fluid presents to a transmission is the small particulate causing wear or sticking a solenoid valve in the valve body. No OE internal filter is going stock that from happening, no matter how old or new the filter is.
18 years in a FS/AMU. 2 of my trips to Kunsan were in phase so not flight line. 5 more years as a civilian in UAE. All F-16s Block 15 to 60.
Service depts like to write their own rules and recommendations then stick it on you if there was a failure.
I have no doubt that if a dealer services a vehicle using their "BG" machine and fluids, if there was a problem and the manufacturer asks about service history, fluids, etc, the dealer will lie and say everything was maintained on schedule and proper fluids used.
I do pan drops on anything that allows it. new filter and fluid. if it’s my personal or family vehicles i’ll pull a cooler line off and start the vehicle until the fluid changes to new fluid. transmissions draw through their filters so i like to keep restriction down.
Had a 2006 Forester doing weird things. Had a fluid change and it still did weird things. Brought it to an independent mechanic who was concerned but said trying a full pan drop, new filters and cleaning internal screens might help if it's never had a pan drop. Issue went away after that. Shifted silky smooth.
Not sure if we just lucked out or how often that's the issue and "transmission rebuild" as recommended by a place is just the easy diagnosis?
I hated dropping the transmission pan for a filter replace on my GMC canyon (because you have to disconnect part of the exhaust pipe to access). But I will continue to do so to replace the transmission filter as this truck is a keeper
Dropping the pan is always better. The filter is secondary, the primary concern is getting the pan and magnets clean.
Change the filter if you don't know how old it is or if it looks / seems loaded.
Pretty common on all Toyota applications, at least trucks (A750/A760/AB60). Even CCN says don't bother dropping the pan.
Not sure about Nissan.
Yes still under warranty. Already did it. I'll be the guinea pig. Maxlife says suitable for MB 236.17, which is the parent spec. It shifts better and smoother with the maxlife. Midas database shows it's a suitable replacement.
That's crazy, I called Valvoline customer service and ask which fluid I could use in my 21 Nissan Titan. They were actually rude and told me they did not have a fluid for that transmission . I'm going to follow your lead and use Maxlife. Thank you
