This is a general discussion i'm hoping to open up but, in my particular case the application I have in mind is a 2021 Toyota Tacoma (6MT) which as far as I've read has a VF2CM transfer case. The Manufacture suggested fluid is 75W Gear oil.
A little back story is that for me, the Toyota juice is un-abtain-ium. My local dealer (which is terrible) says no such fluid exist. I've ran the Redline MT-LV with nothing to talk about in regards to it. Worked fine, came out as clean as it went in. Reason I didn't use it again is because I could only get it for $50 a litre and only after a month of shipping time. Presently I have Amsoil syncromesh fluid in there. My only concern with it is that the truck feels like it has alot more drag, the truck used to coast obscenely well but ever since filling with syncromesh fluid the truck noticeably slows down when off the gas. Cold weather shifting from a -40*C start is fine. You (usually) need to have a little wheel speed to get 4wd to engage but that's nothing new from factory nor other 4WD trucks i've owned/driven. I've noticed no change in fuel economy and within reason, fuel economy isn't a high priority for me... I don't think it's possible to drive a Toyota truck and have fuel economy as a high priority anyways but thats another topic.
Fast forward to present day, it's coming up on time to change my driveline fluid again. If I can find Redline's MT-LV for a more reasonable price, i'm interested in trying it again to see if the additional drag is just in my head or if the Amsoil syncromesh is actually that noticeably thicker. I am aware of the viscosity difference on paper. If Redline is out of the question then I was planning to just run Syncromesh again, until I got the Idea of running DCT instead. For me it would be the Amsoil flavour as it's the best bang for my buck.
(**TLDR**) As far as I can Understand, I see no reason why DCT fluid can't be used in place of 75W for this transfer case. It's closer in viscosity to the manufacture suggested fluid and for the most part a DCT is (kinda) like an automated manual transmission. Combined with the fact that a transfer case really doesn't see any load unless you're in 4WD, I feel like this would be closer to the ideal viscosity for it but much easier to source.
Barring a glaring reason that i'm missing, I'm planning to fill my transfer case with it to see how it does. I am a licensed mechanic so aside from the time and financial aspect of the transfer case being ruined I don't have much to lose. Curious to hear the thoughts of more savvy people than I
