Dakota alignment specs
Kansas, USA
The techs was concerned about the numbers on the rear of the Dakota. Anyone with knowledge on how these numbers look? The junk Primewells are cupping on the inside but pretty sure that shocks. Had to take it back 4 times before they found the bad tire, 3 times to align it right. BUT they did a excellent job explaining all the issues at least.. I was told prior the rack was bad but it's just the bushings.. that's a lot cheaper! Rides and drives fine now.
How do you even get this with a solid rear axle? I think their machine is screwy.
Grandpa had it since 02-03 and I know he never wrecked it but most of the miles was put on by the first owner. I was thinking of getting limited slip later this year so might just swap it out.
