D1 / Gen 3 Approved Oils Wear Ranking ?
I believe that in a well designed engine such as the Duratecs in my Fords, the Skyactiv in our Mazda, the 1ZZFE in my Corolla etc...that using any oil that meets the recommended spec. (including brands such as Supertech, Kirkland, STP etc...(store brands) changed at decent intervals (5 to 7K depending on usage....short trip vs. highway miles) will allow the engine to last hundreds of thousands of miles.
Having said that....I believe that those who extend their OCIs to 10K and beyond would be better served using oils such as Mobil 1 Extended Performance, Castrol EDGE Extended Performance gold, HPL, Amsoil etc...Since I'm not going to do extended OCIs....I'm satisfied that any D1G2 or D1G3 oil is going to
suit my needs fine and serve me well.
I believe within a G1/Gen 3 or SP specification there will be oils which exceed the minimum requirements for wear . Marketing terms will be used by stating “exceeds wear requirements by 25% , 30% , etc” . I use Mobil 1 Extended Performance 5w30 so I’m not concerned that my engine will wear out . It would just be nice to know how G1 / Gen 3 , SP oils really perform with respect to wear levels .
Okay I don’t think you’re really grasping this concept mechanically.
Wear levels compared to… what? And how would you compare them?
Wear levels compared to other oils in the same category such as D1 /Gen 3 5W30 oils in similar engines . *Perhaps the only way to easily test is run three 5K mile OCI’s using three different D1/Gen. 3 rated 5W30 oils and then have used oil analysis tested at Blackstone to compare wear levels ? Does anyone else care about wear levels of their chosen engine oil as compared to other engine oils of a like comparison category (D1 / Gen 3) ?
You are miles from what would be required to actually compare different motor oils in regards to wear. An uncontrolled $30 spectrographic analysis is wholly inadequate for this purpose. Sequence VIII tests that include ASTM D6709 would appropriate.
But wear is really a minor concern in any modern fully formulated oil. All oils have good wear protection, those "35% better" statements are mostly meaningless, a 35% change in an already small number has virtually no relation to anything that would be noticed. @Patman is correct in his statement above.
If all blenders and manufacturers had to do to obtain an API license or a manufacturer approval was to send a sample to Blackstone (and then have Bitog members analyze the results) then they would be all over that.
Even in a perfect world if you could figure out which oils might show lower engine wear and rank them accordingly, I would be willing to bet that the difference between the major brands would be too close to call. In other words the lowest ranking oil might get you 400,000 miles out of your engine and the highest ranking one would be 410,000 miles. But we’re never going to get that kind of data.
And yes we do care about engine wear, but at the same time how many people on BITOG have ever experienced an engine wearing out on them?
Do you have a GM engine that recommends using d1G3 oils, or is this just a random question?
Mobil 1 Extended Performance meets or exceeds numerous API specifications and also multiple manufacturer requirements. It’s a good oil from a major supplier. As long as it satisfies your vehicle’s recommendations, use it without worry that you’re “missing out” on anything. 👍🏻
Specifications and Approvals​
This product has the following approvals:0W-205W-205w3010W-30
GM dexos1:GEN3 LicensedX X
HONDA/ACURA HTO-06 X
This product is recommended for use in applications requiring:0W-205W-205w3010W-30
Ford WSS-M2C930-A X
Ford WSS-M2C945-A X
FORD WSS-M2C945-B1 X
FORD WSS-M2C946-A X
Ford WSS-M2C946-B1 X
Ford WSS-M2C947-AX
Ford WSS-M2C947-B1X
FORD WSS-M2C962-A1X
GM 4718M X
GM 6094M X X
This product meets or exceeds the requirements of:0W-205W-205w3010W-30
API SJXXXX
API SLXXXX
API SMXXXX
API SNXXXX
API SN PLUSXXXX
API SN PLUS RESOURCE CONSERVINGXXXX
API SN Resource ConservingXXXX
API SPXXXX
API SP Resource ConservingXXXX
ILSAC GF-6AXXXX
CHRYSLER MS-13340 X
Chrysler MS-6395XXX
FORD WSS-M2C960-A1 X
FORD WSS-M2C961-A1 X
Some may argue that a D1G3 with a lower price, has a better wear ranking ... At least on your wallet!
