For those who own the Mazda CX-5 Turbo, what oil grades and brands are YOU using?
Both have oil consumption issues? That's disappointing. I was considering a CX-5 2.5T for my wife at some point.Had two 2.5T engines, and they both require oil top up at some point in the interval. One had no recall or TSB issues, and the newer one is included in the valve stem seal TSB range. Judging from online talk, the fix doesn't necessarily solve the consumption.
2024 Mazda CX-5 signature. i use Pennzoil Ultra Platinum 5w30 that i buy on sale at Canadian Tire. change oil at 8000 kilometers, and i always use the Mazda oil filter.
2011 Hyundai Sonata Limited 2.5L NA - Whatever 0W-20 is on sale
Well I got the displacement wrong. Should be 2.4L, not 2.5L. But the engine is a Theta-ii.Is that a misprint? Is yours a 2.5 Smartstream engine (2021), not 2011?
Seems to be the same weirdness on non-turbo models also.2023 Mazda CX-30 Turbo here. Same powertrain.
I purchased a CPO car with 3k miles on it. At 5k, I changed whatever the Mazda store put in it with PP 5W30 and a Mazda filter.
Saving the two (free) changes for winter weather.
I'm not convinced Mazda understands the refill volume as the Owner's Manual dictates 5.1 quarts, but that was just above the add point on the dipstick. I put in closer to 5.5 quarts and it's about 3/4s of the way between add and full.
5.1 for the non turbo, 5.5 for the turbo. Dad had both!2023 Mazda CX-30 Turbo here. Same powertrain.
