CV Joint Removal ... Mazda 3
Ndx
IL
Hi,
Guys I will be replacing CV boot on my drive shaft ...
I'm planning to take it apart on the bench as suggested before by you guys.
http://www.thaimazda3.com/svmanual/esicont/en/srvc/html/B3E031325501W01.html
I did some research ... how to separate CV joint from the shaft ...
And Then I cam across Mazda Manual ...
And It looks like the housing is not secured with anything else then a boot ?
Its just really weird how they tell you to install inner ring then cage with balls then housing .. ?
I was sure that
inner ring + Cage + balls goes to housing then I clip it on the shaft .. and according to that Manual
I place inner ring on the shaft lock it with ( C Clip )
I put the cage with balls on it ?
And the I put housing ?
I hope that its clear what I'm trying to say here ...
