CV Boot Clamp Saab 9-5
MD
I had a front wheel off today on my Saab 9-5 and came to find that the cv boot had slipped its clamp. It's on the smaller diameter end of the outer shaft, and very little grease has escaped.
I'm wondering whether I can get a tool and just put a new clamp on it. The boot doesn't appear torn. Any advice?
Of course you can. For the time being if you must drive it, I'd put some nylon wire-ties on to keep in and out, what should be kept in and out.
Thanks for the replies. I'll give a zip tie a go first!
Originally Posted by Trav
+1 on the zip tie, for a more permanent fix..
https://www.amazon.com/Interstate-P...mp;psc=1&refRID=DW646CWX6V2D1E106Y6S
The Japanese are fond of that type too - I've used them, there is a bit of a learning curve to tighten the clamp and staking down the locking tangs.
I've used these on a different application, imagine a zip tie but metal and self-locking - it might work:
https://www.amazon.com/30-Stainless-Steel-Cable-Ties/dp/B006676E38/ref=sr_1_13?dchild=1&keywords=Stainless%2BSteel%2BLocking%2BTies&qid=1593120378&sr=8-13&th=1
