Ran this for 7000 miles on Mobil 1 5w30, did an oil drain only, filled with frankenbrew and went another 5000 miles. Looks good IMO although I don't plan to run oversize filters quite this long lol. ADBV was still nice and pliable, base gasket still fairly soft. At the bottom of the can are visible deposits from some neodymium magnets placed on the outside, there are a few others around the side of the can that are not visible. The drained oils (both M1 and frankenbrew) were about normal, dark but still translucent, and no noticeable grit or debris found at the bottom of the drain pan. Now running Wix 51516 (oversize) and Pennzoil Ultra Platium 5w30, planning to go around 7500 miles. Although they are both oversize filters, the Wix 51516 is slightly longer than the FL400S and did not quite fit onto my Tacoma. I removed about 3/8 inch of material from the end of a stabilizer bracket for the transmission cooler lines, and now the Wix 51516 fits. Enjoy.
