Originally Posted By: WellOiled
Does anyone know how to test the bypass valve function? Begins to open PSI and fully open PSI.
Measure the force required to make it start to open and the force it takes to keep it wide open. Then find the area of the valve surface. Using those two measurements, you can calculate the PSI required on the valve surface to open it like you did when measuring the force required.
I like the idea for filter autopsies.
That would work for dome end bypass but what about the combo valves and the one Motorcraft uses.
When I posed the question, I was thinking differential pressure gauge on the vehicle. So you would know if the filter was in bypass or not.
Thanks
No, you couldn't really do the test I described on a combo valve of a base end bypass valve like WIX or Motorcraft uses.
You could use an accurate differential pressure gauge with high resolution across the oil filter to see when the bypass valve opened. I think Jim Allen (old member here) did exactly that. When the delta-P curve slope changed is when the bypass valve started to open.
Thanks
