[Cut Open] Fram Tough Guard TG3593A
Bud_One
Site Donor 2025
Spring,Texas
This filter came off my 1997 Accord - 2.2 4cyl - 163k miles on vehicle -
5,816 miles on filter - no start up issues. Replaced with an Fram Ultra.
No rips or tears - anti drain back valve very pliable.
Seam area is a little funky looking, but shouldn't have caused any problems. Obvious seal impression rings around the center tube hole in the end cap.
I own a 91 Honda Civic Si Hatchback with 488,000 miles, same engine.
I have used many 3593 oil filters from different manufactures.
The following are a list of filters that I have used
Fram-tough guard, used this filter for probably first 100k miles
Purolator
STP
Bosch
Wix and Napa Gold
Super Tech-used this filter for approximately 200k miles
AC delco-used this filter for approximately 100k miles
Full
As soon as I found what was inside a Fram filter, I stopped using them for good.
I know that Fram makes better ones now if you pay a little extra for the upgrade
In between the use of the above filters, I have used a few others just a few times.
Currently using
Baldwin Filter - and will continue to use these filters until the prices go up
Originally Posted By: 901Memphis
Also very nice and straight paper end caps, as usual.
I fixed it for you.
Purolator
STP
Bosch
Wix and Napa Gold
Full
Currently using
So even though they worked for you for 100,000+ miles, you only decided they're garbage after you saw one cut open? Lots of more expensive filters use fiber end caps. Don't understand why they scare people.
Exactly I have noted the same many times on my own cut Frams. Still not good enough for the Framophobites who are really sensitive about HOLES in their Purolators.
IS that a typo??
I was wondering the same thing! If it isn't he must have been using tuf oil
