The Bosch D+ and PureONE oil filters are excellent oil filters. However, there has been some disagreement as to whether these are the same filters in different packages or different filters. To try and answer these questions, I cut open a new Bosch D3330 and a new P1 PL10241, the filters recommended for my vehicle.
As will be seen later, the filters are the same diameter and height, but their other physical characteristics differ:
Code:
Measurement D3330 PL10241
Total Weight 346 gm 255 gm
Baseplate Wt 187 gm 125 gm
Empty Can Wt 74 gm 48 gm
Filter Wt 73 gm 70 gm
Filter Pleats 57 65
The Bosch D+ is a more robust filter than the PureONE. The baseplate and can are both heavier than the P1.
In the following photos, the D+ is always on the left.
Packaging:
Filters:
Baseplates:
The Bosch baseplate has 8 round holes, while the Pure baseplate has 7 oblong holes.
Cut Open:
Both ADBVs are silicone, despite the difference in color.
Taken Apart:
Both filters use flat springs to hold everything together.
Bypass Valves:
Very different bypass valves.
Center Tubes:
The center tubes appear to be identical.
Filter Elements:
On cursory examination, the two filters appear to have the same filter element. As can be seen by this closeup, the PureONE element is slightly lighter in color and not as thick as the D+ filter.
The bottom line is that these are clearly not the same filter in different packages.
Code:
Filter Pleats 57 65
Packaging:
Filters:
Baseplates:
Cut Open:
Taken Apart:
Bypass Valves:
Center Tubes:
Filter Elements:
