Cut open an used Purolator P+ L14477
Austin, TX
I am on vacation this week. I changed my oil and cut open a used L14477. Sorry my camera literally blew up a while ago. The battery exploded when it was on my desk. Saw it as it happened too... Also kanling already has nudie pictures of this filter posted.
Anyways, I used pliers-type of filter wrench when I installed this filter (could not turn it ¾ turn with oily hand), and managed to put some scratches and 1/4 inch dents on it. So I wanted to cut it open and see if the element was okay. (Which I thought it would be, didn’t think the can would leak either).
I cut it open with a hacksaw in the garage. Some lady walked by and looked at me like a nut, as I sat on the floor and sawed a filter open on my oil drain pan.
The can seemed to be composed of a light alloy of copper. As I sawed through it, the metal has a hint of copper tone.
The filter was on for 5 months and 6000 miles on Mobil 1 5W30. The scratches did not even rust. The biggest dent cleared the element and as far as I can tell there is no damage. The ADBV was still soft, but it could be showing first signs of hardening. I bent it 90 degrees and it took 15+ seconds to fully regain its shape. I do not know if this is normal but it seemed to seal against the base plate well, as Purolator has a ring of lip on the base plate to mate with the ADBV.
BPV was well shut. I am very doubtful that it ever opened – it opens at 14-18 PSI and this is a low restriction filter, this was a hot summer run on Mobil 1.
The filter itself was good. Nothing (besides dirty oil) to be found in the element. The element seemed very robust. One bad thing though, the crimp strip was 1/6 of an inch too short to enter the glue, like someone else reported on a Quaker State unit.
This is it. I then made a trip to Walmart and dumped the filter and the old oil.
2002 Toyota Camry SE 2AZ-FE.
CT I believe you have the same motor on a Highlander? And Kanling an 05 Cammie?
Yes, 05 Cam and also an 03 Corolla (I use same filter). Those I pretty much just change the oil on. The car I drive is a 94 Saturn. Someday one of the Toyos will be mine (only when the wife or mother gets an upgrade
I see you are serving your duty as a husband and son.
It is good to be single. I only service my own rides, and have a two car garage all to myself.
What happened to the " " button???
quote:
This is the filter I am planning on using in my 2.4L Highlander. Thanks for the info.
Yep. It was a good filter, took my wrench abuse well
Use only cup wrench on Purolators. The can is thinner than most.
The only concern I have is the short crimp strip. Probably does not mean anything, as the uncrimped section is tightly pinched. If I have to guess, these metal pieces are probably made to a +.00/-.XX type of tolerance.
I put on a new L14477 BTW. I am doing a 15K Mobil 1 Extended Performance drain with 7.5K on the L14477, then 7.5K on a PL14477.
"The filter was on for 5 months and 6000 miles on Mobil 1 5W30."
You don't like to take Mobil 1 past 6000 miles ?
No - my car just hit 30K even, and I am starting extended drain, since I moved into the burbs and doing more driving. This will be a easy starting mileage to keep track off.
