One thing I do not like about the MXS 5.0 is that temperature compensation is not applied to the float voltage. It is 13.6 volts (after 24 hours) at all temperatures, whether it is 120F or 10F, according to CTEK tech support.
Battery Minder I believe does apply temp compensation to the float voltage, but their problem is they set the target voltage too low for some AGM batteries. And if you go to their documentation, they give conflicting information about what target voltage they are using for float. For example, with the 128CEC1 the printed manual says the float voltage is 13.2V at 77F. The online manual says the float voltage is 13.6V at 77F.
This does not inspire confidence in Battery Minder.
