CrossClimate 3 Tire Release?
Just an FYI:
OE tires - the ones that come on new cars from the assembly plant - are designed for low rolling resistance. The car makers specify the RR and the tire manufacturers do that by sacrificing treadwear and/or traction, especially wet traction.
That means that people normally take a hit in mpg when they replace OE tires with aftermarket tires.
Actually, OE variants are made for whatever the OE wants, if the tire maker is willing to do so. They might be optimized for RR (fleet fuel economy). They might be optimized for low noise, cornering grip, or wet braking for government testing, customer first impressions, or consumer reports style testing...and wear faster because of this.
Back in the day of the MXV4, my father was part of a team that was tweaking OE fitment tires for Honda. Several iterations. Change tooling tooling at the factory, make 100 tires, test, rinse, repeat. Late nights adjusting tooling and then getting it onto the production line. Turns out Honda was trying to eliminate a very specific in-cab resonance. Michelin's design engineer put a brick on the passenger floorboard and made the resonance go away. At that point it was easier to change the tires than to change the body stampings.
Also, some of the tires sold as "CrossClimate" in the US are US designed, US produced. Some fitments are a different tread, different construction, made in Europe. It's not uncommon for Michelin to have many tires called and marketed under the same names. As we speak my tire shop is discarding some c-metric Agilis CCs made in France and installing Agilis CCs made in Poland (Michelin moved the tooling) which are very different than the lt-metric Agilis CCs made in typical US sizes.
The GY WeatherReady look like they might do the job in heavy west coast rain.
In the end, directional tread is a gimmick, but how a tread pattern looks sells tires apparently. It looks cool, but we went through it with the GY aquatread years ago. Then there was the Michelin hydroedge. Then it went away for awhile. Now it's come back. It's not really better or worse but different.
Perhaps you're right. Those things sure had the look of traction.
They came on my sister's '90 Mustang GT 5MT. Crazy that over the years the same size that came on that is optional tire size on my '17 Accord sedan 6MT and was also one of the sizes listed for '07 Sonata but on higher trim level.
I’m not old enough to remember - was the AquaTread the first “big” directional tire? I figure the current directional craze is just the market cycle coming back around… curious to know if it’s only the first full cycle.
I think the Michelin Hydro Edge came out first.... I think..............
There's a high probability that they will release it soon but it's anyone's guess.
It is incredible that the CC2 beats out all these newer tires in most tests. For example even though the weather ready 2 is highly rated by tirerack in their testing it only matched the wet braking of the CC2 and in the dry the CC2 stops a few feet shorter. The wr2 does perform slightly better in the emergency lane change test.
The wr2 also weighs more depending on the tire size... Sometimes 5 or 6 lb more.... So when the CC3 is released I think we can expect some seriously good numbers...
If you look at the test results you are splitting hairs on many of the qualities. The CC2's are not massively better the the Goodyear Assurance Weather Ready 2. I have a thread going on now showing WR2's on my wife's Volvo-the tires purchased a few days ago.. If the CC2's were substantially better-those would have been put on my wife's Volvo XC60.
As a matter of fact-across all families of tires-A/T-All Season, etc., it's hard to go wrong if you stick with the tires Tirerack usually compares in their competitive tests.
Thanks, that seems to be more aligned with a "GT" tire rather than a "UHP" tire IMO. Got me all excited for a second as I've been waiting for the DWS06+ successor for a while now!
Even if available, I'd still be putting the DWS06+ on the Pilot. They are a very comfortable tire, especially being UHP. I made the mistake of rotating the OEM tires the other day. Old habits die hard. It's going to take a long time to wear them out if I keep watching tire pressure and regularly rotating them.
Bridgestone Alenza came on car. They don't rise to the level of excrement where they need to be replaced immediately. I had a 2020 Ram 1500 which had Nexen tires. They got switched to Michelins almost immediately.
.........I've been waiting for the DWS06+ successor for a while now!
The DWS06+ was introduced on Feb 1, 2021. So it has been on the market for 4-1/2 years. Probably an upgrade will arrive in late 2026 or early 2027. The older DWS06 (introduced May 2015) was on the market for 6 years before being replaced.
https://continentaltire.com/learn/continental-tire-introduces-extremecontact-dws06-plus
https://www.moderntiredealer.com/in...ntact DWS06 | 2015-04-15 | Modern Tire Dealer.
https://www.moderntiredealer.com/industry-news/wholesale-distribution/article/11543874/continentals-extremecontact-dws06-2015-04-15#:~:text=Continental's ExtremeContact DWS06 | 2015-04-15 | Modern Tire Dealer.
Yup. I was hoping for a shorter development cycle to get the DWS06+ on clearance soon :LOL:
Well, looks like I won’t be getting CC3’s to replace my CC2’s. No CC3’s for you!!
When will the Michelin CrossClimate3 tire be available in North America?
The Michelin CrossClimate3 tire launched in Europe in July 2025. Please note that the CrossClimate tires sold in Europe differ in design from those sold in North America. This is because consumers in each market have different priorities for tire performances based on driving style, vehicle types, geography, and climate. As a result, Michelin has tailored the tire construction to meet the unique needs of both regions. While the CrossClimate3 tire has been available in Europe since July 2025, North America will continue with the Michelin CrossClimate2 tire for the next several years. As a part of the Most Awarded tire brand in the U.S., the Michelin CrossClimate2 tire continues to offer industry leading performance and is designed to perform in all weather conditions, with excellent wet and dry braking. Based on our internal testing, the Michelin CrossClimate2 tire outlasted 10 different competitors and also lasts nearly 2 years longer than the new Goodyear Assurance WeatherReady®2 tire.
https://www.michelinman.com/auto/tires/michelin-crossclimate-2
It appears Michelin North America is resting on their laurels on the CC2, while other manufacturers are continuing to improve their offerings.
I think it’s likely that they feel the CC2 is still competitive against the latest challengers and will keep the CC3 as a trick up their sleeve to roll out to North America as soon as they actually feel threatened.
The way I read that was that the tires needed to be different because the customers wanted them to be different, not that one was better than the other. Put another way, the Europeans wanted their tires to do things the US and Canadian consumers didn't want and since tires are compromises, they are different.
