TallPaul
No knobs. Wife's '92 Aerostar has a couple knobs (one if volume). Don't know if that radio would slide into the '95 or not. The radio on the '95 is basically impossible to set up with jacks. Can't even tell which is the amp outputs.
Well, I'll try the Radio Shack 100 watt (50+50) amp I got at a garage sale for $2. The fuse holder was partly melted and I am replacing that part. I'll run a smaller fuse (10 amp instead of 15) to begin with and see what happens. It may work, or I may need improved signal with either the FM modulator, or a direct input of the MP3 into the amp which has the RCA inputs (low input) and speaker wire inputs (high input).
